SSM 2021–2022 Super Duty ML1Z-15790-C Roof Opening Panel Motor Replacement — 55328
Special Service Messages
Imported from NHTSA data · last checked Nov 17, 2026
Ford Tremor Forum
Forum Support 🛠️
Special Service Message · SSM 55328
This is a Special Service Message, not a recall. SSMs are informational notes Ford sends dealers about a known condition or a change in procedure. They are not repair orders, and they don't by themselves change what is covered.
Published: Nov 11, 2026
Applies to: F-250, F-350 (2021–2022 model years)
Also listed in the source (outside this forum's coverage): Expedition 2021–2024, F-450 SD 2021–2022, F-550 SD 2021–2022
Summary (official text)​
Some 2021-2022 F-Super Duty and 2021-2024 Expedition/Navigator vehicles may require replacement of the ML1Z-15790-C roof opening panel motor for various reasons. Early production service parts with this part number contained a software concern that prevented the initialization procedure from completing after installation resulting in the roof opening panel not fully opening and/or becoming inoperative. Make sure the box on replacement motors has a label that states "Flashed With New P-set and Static Logic Table." The motor itself will also have a circular green sticker on it. The supplier has committed to installing these labels through September 2027. If no green label is present on the motor, order a replacement ML1Z-15790-C motor from normal service stock.
Sources​
  • SSM 55328 (PDF, NHTSA document 11039957) — Nov 11, 2026
Details from NHTSA as of Nov 17, 2026. If NHTSA or Ford revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
