- Staff 🛡️
- #1
- Jun 8, 2021
- 201
- 15
Special Service Message · SSM 54601
This is a Special Service Message, not a recall. SSMs are informational notes Ford sends dealers about a known condition or a change in procedure. They are not repair orders, and they don't by themselves change what is covered.
Published: Feb 24, 2026
Applies to: F-250, F-350 (2020–2026 model years)
Also listed in the source (outside this forum's coverage): Bronco 2021–2026, Bronco Sport 2021–2026, C-MAX 2013–2018, Crown Victoria 2009–2011, E-150 2008–2014, E-250 2008–2014, E-350 2008–2019, 2021–2022, E-450 2008–2019, 2021–2022, Edge 2008–2024, Escape 2008–2026, Expedition 2008–2017, 2025–2026, Explorer 2008–2026 and 20 more
Summary (official text)
Ford and Lincoln vehicles equipped with wired keyless entry keypad systems and accessory wireless keyless entry keypad systems may or may not come with a wallet card containing the master code. Unlike the integrated wired keypad, the accessory wireless keypad master code cannot be retrieved from the vehicle using a diagnostic scan tool or from the label printed on the body control module (BCM). The Factory Keyless Entry Code application within the diagnostic scan tool will not provide an applicable master code for the accessory wireless keypad. If the wallet card for an accessory keypad is not available, the "Wireless RF Keypad Diagnosis Guide" can be referenced and provides direction on how to retrieve the master code. This guide is located under the Workshop Manual tab > Accessories > Installation > Wireless RF Keypad Diagnosis Guide > PPT C > Step C2.<br /><br /> Note: The only available keypad for some vehicles from the assembly plant is the accessory wireless keyless entry keypad. The integrated wired keypad cannot be installed on vehicles not equipped from the factory with a wired keyless entry k
Sources
- SSM 54601 (PDF, NHTSA document 11029052) — Feb 24, 2026
