SSM 2020–2026 Super Duty Power Train — 54592
Special Service Messages
Imported from NHTSA data · last checked Nov 29, 2026
Ford Tremor Forum
Forum Support 🛠️
Special Service Message · SSM 54592
This is a Special Service Message, not a recall. SSMs are informational notes Ford sends dealers about a known condition or a change in procedure. They are not repair orders, and they don't by themselves change what is covered.
Published: Feb 17, 2026
Applies to: F-250, F-350 (2020–2026 model years)
  • Equipment: equipped with a 10R transmission
Also listed in the source (outside this forum's coverage): Bronco 2021–2026, Expedition 2025–2026, Explorer 2020–2026, F-150 2017–2026, F-450 SD 2020–2026, F-550 SD 2020–2026, F-650 SD 2024–2026, F-750 SD 2024–2026, Mustang 2024–2026, Ranger 2019–2026, Transit 2020–2025
Summary (official text)​
For 2017•2026 vehicles equipped with a 10R transmission, a revision to the Road Testing Vehicle procedure has been made in the WSM, located in Section 307-01 > Diagnosis and Testing. This updated procedure improves the diagnosis of customer reported transmission concerns and aids in locating the proper root cause. During diagnosis and testing, details regarding whether the condition is more prevalent when the vehicle is hot or cold, throttle percentage at the time of occurrence, vehicle speed, the specific shift involved, and whether the issue occurs during transmission engagements (N>R, N>D, R>D, or D>R) should be noted. Engineering requests including these detailed operating conditions that will significantly assist with root cause analysis. Diagnosis, testing, and repair should use established labor times outside this article.
Sources​
  • SSM 54592 (PDF, NHTSA document 11029081) — Feb 17, 2026
