- Staff 🛡️
- #1
- Jun 8, 2021
- 201
- 15
Technical Service Bulletin · TSB 25-2572
Published: Nov 26, 2025
Applies to: F-250, F-350 (2020–2025 model years)
Also listed in the source (outside this forum's coverage): E-350 2021–2025, E-450 2021–2025, F-450 SD 2020–2025, F-53 2020–2023, F-550 SD 2020–2025, F-650 SD 2021–2025, F-750 SD 2021–2025
Supersedes: TSB 25-2322
Summary (official text)
This article supersedes TSB 25-2322 to update the Service Procedure, Labor Operations and Parts List. Some of the vehicles listed in the Model statement above may exhibit an upper engine ticking or tapping noise at idle. Customers may also report experiencing rough engine performance, engine misfire, or a malfunction indicator lamp (MIL) with diagnostic trouble code (DTC) P0301-P0308 in the powertrain control module (PCM). This may be due to camshaft and/or valve tappet having excess wear within the engine assembly.
Sources
- TSB 25-2572 (PDF, NHTSA document 11025854) — Nov 26, 2025
