TSB 2020–2025 Super Duty Upper Engine Ticking or Tapping Noise at Idle — 25-2200
Technical Service Bulletins
Imported from NHTSA data · last checked Nov 29, 2026
Ford Tremor Forum
Forum Support 🛠️
Technical Service Bulletin · TSB 25-2200
Published: May 19, 2025
Applies to: F-250, F-350 (2020–2025 model years)
Also listed in the source (outside this forum's coverage): E-150 2021–2023, E-250 2021–2023, E-350 2021–2025, E-450 2021–2025, E-550 2021, F-450 SD 2020–2025, F-53 2020–2024, F-550 SD 2020–2025
Summary (official text)​
Some of the vehicles listed in the Model statement above may exhibit an upper engine ticking or tapping noise at idle. Customers may also report experiencing rough engine performance, engine misfire, or a malfunction indicator lamp (MIL) with diagnostic trouble code (DTC) P0301-P0308 in the powertrain control module (PCM). This may be due to camshaft and/or valve tappet having excess wear within the engine assembly.
Sources​
  • TSB 25-2200 (PDF, NHTSA document 11018524) — May 19, 2025
