- Staff 🛡️
- #1
- Jun 8, 2021
- 45
- 9
Technical Service Bulletin · TSB 26-2088
Published: Mar 5, 2026
Applies to: F-250, F-350 (2020–2022 model years)
Also listed in the source (outside this forum's coverage): F-450 SD 2020–2022, F-550 SD 2020–2022
Supersedes: TSB 24-2249
Summary (official text)
This bulletin supersedes 24-2249. Reason for update: update the claim quantity of the torque converter nuts, part number and claim quantity of the front support assembly bolt washers, and part number change of the fluid pan from the Parts List. Reissued 01-Oct-2026 - Added LC3Z-7G091-B to the part list
Sources
- TSB 26-2088 (PDF, NHTSA document 11029923) — Mar 5, 2026
- TSB 26-2088 v2 (PDF, NHTSA document 11037979) — Oct 1, 2026
