2-way or CB Radio
If I understand GMRS correctly, one thing to keep in mind is that the power level for transmission is limited by channel. I took this to mean that GMRS handhelds are not necessarily able to communicate with GMRS mobile radios.
Somebody more experienced correct me if I am wrong.
I am no experiment, but from what I have read most of the mobile radios say they are compatible with the handhelds.
Here’s a good reference table with the frequencies, power limits, and channel numbers for all the channels:
Power limits don’t impact interoperability between radios. A handheld GMRS radio operating at 5 watts can talk to a GMRS mobile radio operating at 50 watts just fine at a technical level.
In practice you may see that breakdown as the radios get further apart with more obstructions. The higher power coming out of the mobile radio can reach the handheld radio, but not the other way around.
That isn’t unique to GMRS of course. That’s just the physics/realities of radio communication.
Where there are some incompatibilities is FRS vs GMRS. FRS radios are handheld only and, as can be seen in the table linked above, shares frequencies with GMRS, albeit at lower power levels for many of the channels.
The incompatibility is that GMRS has access to more frequencies to allow repeater use. FRS radios cannot access to frequencies. If a GMRS radio is operating on those frequencies, then an FRS user will be unable to communicate with that radio.
But it’s possible to get a GMRS handheld with access to repeaters, so no mobile/handheld distinction there.
And then you throw in ham radios with the MARS modifications and antenna tuned for the frequency you can really reach out but that entire antenna thing is wizardry coupled with science and math
This is the antenna I’m planning on going with
First, it's worth noting that almost all mobile Ham radios cap out at 50 Watts (practical limitation, not legal), so you aren't going to get any more reach than a GMRS radio on the same frequency. GMRS allows for interchangeable antennas as well. The main way you can go further with Ham radio is operating on bands in lower frequencies (GMRS operates in UHF). VHF is the most common one for day-to-day use, though HF is where you start seeing people making contacts across the country, and the globe.
Second, to clarify for other folks reading the thread: transmitting on FRS and/or GMRS frequencies with a radio that isn't licensed for it - including all Ham radios - is illegal. Up to you if you want to do it and you can evaluate the risks involved yourself, but it is against the law.
For background, MARS stands for "Military Auxilliary Radio Service" and is a program amateur radio operators can join so that their services can be used by the military when needed. Based on my reading, the last time it was heavily used was during the Vietnam war but the prevalence of newer technologies has meant it's needed far less.
MARS operators, when operating on behalf of the military, need to operate on frequencies outside of the amateur bands. Quality amateur radios are blocked from transmitting on frequencies outside of the amateur bands; however, to allow for MARS operators to use the radios, you can perform a hardware modification to unlock transmit on all frequencies - usually removing a resistor or similar. This is the MARS mod.
Performing the modification is legal. Transmitting on frequencies for which you aren't licensed is not. (Related to this, don't get me started on Rugged Radios.)
If you choose to perform the MARS mod, please operate responsibly.
You make a point. But what you are suggesting also requires a lot of extra effort and knowledge that most are not willing to engage in. Like studying to get a ham license. Most casual users just want to click a channel (ala CB) and key the mike. Programming repeaters and frequencies is beyond what the average person wants to do, the advantages notwithstanding.
I get it... I don't think it's too much more work though, particularly if you're just looking for simplex radio to radio operations.
I have a Yaesu and it can do a lot I never bothered to figure out... there are lots of youtubes if you really want to figure it all out, but I don't need it. The programming with a cable and your computer is easy though.
Where I am in we restrict our radio to radio operations to VHF 144 mhz HAM band so we don't interfere with any real operations and there's not many around to hear anything on the those bands in my experience, particularly in the mountains and backcountry. I have marine and air restricted radio licenses but am not a licensed amateur, I don't sweat it... I'm not carrying on conversations talking in populated areas... maybe one day I'll do a HAM license, but I'm not looking to talk to those guys so not sure the point other than the frivolous semantic legality.
On the active logging roads you're calling your mileage on commercial bands, there is an overriding safety concern here so again I don't sweat it... but you can/maybe should get a limited commercial radio, write a letter to the needs to operate on commercial bands, and pay for a $41 fee, but it changes nothing... same calls to the same trucks not driving you off the road because they know you're coming... better a modded HAM than nothing and a surprise rough ride down the mountain when you get run off the road in that hairpin switchback.
And if you get in trouble, particularly somewhere remote... someone is more likely to hear you on VHF than the other options discussed - know the freq your local search and rescue uses, know the emerg freq on the aircraft and marine bands, that you can transmit on with a modded ham - legally now at that point because distress calls take priority over licensing - that's more likely to get your ass saved.
That's all just my reasoning to it... to each their own... but as said above operate responsibly. Don't just pick any freq and go to town...
  • Like
Reactions: Gus
Not CB. It's only good for talking to truckers on the highways. The range is severely limited. VHF is what everybody is switching to now. A lot of people start out with the cheap Baofeng handheld radios and a long antenna then graduate to a vehicle-mounted more powerful radio if they want more idstance.
The ham license course isn't that bad. There are apps and websites that help you study. The questions on the test are mostly the same as the practice questions.
Maybe I’ll do the HAM test. I’ve loved the idea of having a HAM in the truck. I need something - and we’ve been using HAM in the woods (small hand held ones for hunting). Can’t beat the range, for our local wooded area. Seems like we get a few miles of range.
Compared to other options discussed agreed that you'll have more likelihood on VHF, but I will strongly discourage anyone reading this from relying on Ham radio in the wilderness as an emergency resource. Obviously if it's all you have, or you're trying all your options, then it's another tool in the toolbox. But don't go out there expecting it to work.
(I will also note that I'm biased by my area to be thinking of mountainous terrain. Perhaps in flat-lands it's more reliable.)
It's far too easy to wind up out of reach of any repeaters, particularly in mountainous terrain, and ultimately you are relying on a good Samaritan happening to be listening on the frequency you're broadcasting on. And don't forget the amount of prep it takes to:
  1. Find the frequencies for the repeaters in the area you're going to.
  2. Figure out which ones are actually still active and which ones have been taken down, but the online database hasn't been updated to reflect it.
  3. Documenting their location geographically so you know which repeaters to even attempt to contact based on your location.
  4. Documenting everything in a way that is accessible while you're in the wilderness, in an emergency.
Impossible? No. A ton of tedious prep work? Yep. Likely to fail (no one responds or you can't reach a repeater) when you most need it? Yep.
Again, as another tool in the toolbox I'll never discourage it. But your best bets are:
  1. Tell someone you trust that you're going into the wilderness, your plan (times, locations, etc), when to activate emergency resources when they haven't heard from you, and which emergency resources to activate (most likely call 911 and they'll redirect appropriately, but consider if your emergency contact is in a different country from where you are, which is quite possible with the US and Canada).
  2. A satellite communicator, preferably 2-way (e.g. Garmin InReach or Spot X). This serves two purposes:
    1. Most obviously allows you to activate an SOS signal yourself.
    2. Less obviously allows you to communicate with the person you trust from bet 1. Without a satellite communicator, it could be days that you're expected to be out of contact (depending on your plans), which means it could be days before emergency services are activated. With a satellite communicator you can have a much more frequent communication plan (at least once per day), with a fresh location, which means emergency resources will be activated far more rapidly and have a much more accurate location for you.
While Apple's newest satellite SOS feature (iPhones 14 and newer) is great, I don't consider it a true replacement for a Garmin or Spot device purely because of durability and battery life. But it's certainly better than nothing, and will absolutely save lives (already has!).
I again want to emphasize the legalities here. There is a lot of gray area created by the wording in the law. If you are in a true life or death situation, you're probably OK (not a lawyer, this is not legal advice), but if you interrupt any kind of major service the FCC will come down hard on you, and rightly so, if it wasn't a true life or death situation. And judging whether it was a life or death situation isn't up to you; that's up to the FCC initially (whether or not they pursue legal action) followed by a judge.
Hopping onto other public use services with a Ham radio (e.g. FRS, GMRS, MURS, etc) are certainly far less likely to garner the FCC's interest if you aren't doing it with a ridiculous amount of power, but there is no difference when it comes to whether or not it's legal.
An easy example, having your vehicle break down in the wilderness and being scared most likely wouldn't count unless you've exhausted all other options and are close to death from the elements and/or lack of food/water.
Of course the true lesson in all of this is to have multiple tools in the toolbox in the case of an emergency. Though Ham radio is the one I personally have the least confidence in when it comes to the wilderness.
(Side note: As a tool for non-emergency situations, I love radio. Helping out at an event, working a SAR mission, or communicating between vehicles it's invaluable. But those situations are dramatically different than a remote emergency situation.)
(Side side note: I believe that marine VHF is a different beast, though I have no direct experience with it. Range is far superior as the ocean is flat, barring the curvature of the Earth. And I believe the Coast Guard near major ports are monitoring the marine emergency frequency for distress calls, so if you're moderately close to a major port then you know someone is listening. Knowing someone is listening is a game changer for reliability.)
I can vouch for this. I operate a 26 foot pleasure boat out of Cape Cod during the summer months. Coast Guard is indeed monitoring Marine 16, at least in that area. The waters off the Cape are a REALLY good spot to get yourself into all manner of trouble, so maybe it is not the same everywhere, but I will generally leave my handheld on 16 while I'm piddling around the house and there is often something going on with a Coast Guard response.
  • Useful
Reactions: ccw
I have watched my fair share of XOverland https://www.xoverland.com/overlanding-blog/overlandingcommunications/ , and they have a super easy write-up on radios, as well. Other than Rugged Radios (which it seems @ccw is less of a fan on) I found the information easy - and also helped me choose my pathway forward. I am going to get my HAM Technician License. Then I will add that to the truck - but first the cell booster. Then I will use (I think) two NMO antenna mounts off the third brake light. This may change as I do more research, but it sounds like the best idea for me so far.
The only sticking point I will likely have is others who are NOT running HAM when I try to do a group thing. However, I am thinking all my hunting buddies are running HAM, so this will be my primary "group" most of the time. Unless I put together a Vermonster group off-road weekend or something.
Vermonster
Here is my antenna setup for my weBoost and VHF/UHF amateur radio systems.
Agreed with ccw on it being an additional tool, but not a reliable source for emergencies. Although I am a licensed Ham and carry a radio with me I still carry the Garmin Inreach when I am out hunting or hiking in remote areas. Plus, where we camp is about an hour plus from cell signal and the communicator allows me to relay back home when needed to keep the wife at ease so I can keep going...
As an Extra Class Ham it amazes me that people who would not loan out their truck to an unlicensed person is willing to jump on a repeater and use frequencies that by law are reserved for Amateur radio. Repeaters are not "free". They are licensed by the FCC to clubs or individuals. They are not public property. There is expense involved in setting up and maintaining a repeater as well as time by the Trustee to insure they keep operating properly.
Repeater Trustees make them available to licensed Hams as a public service. How many Tremor owners are willing to loan out their truck as a public service to an intellectually lazy person who is unwilling to study for the driving test and show some ability to control the vehicle on the road? No one on this board I am sure.
When an unlicensed person uses Ham radio it is considered to be malicious interference. It is very easy for Hams to know that an individual is unlicensed even with fake call signs. The best thing to do is study for the Technician test. Take the test. Pass the test and apply to the FCC for your license. You will find that there are Hams willing to help you and if you really need the frequencies for non life or death situations, a friendly voice will be on the other end. For a life or death emergency anyone can use the frequencies.
Definitely not a fan, though I won’t preemptively do a rant post about them lol. If someone wants to hear it, I’ll type it up. :ROFLMAO:
Building the suspense - I like your style, @ccw!
  • Haha
Reactions: ccw
