#2 misfire on start up. Thoughts/ advice
Thought I would give an update. 2 ford dealerships gave me the run around basically asking me to catch the issue when it is happening and limp into the dealership so they can see what’s going on as it is happening . Both said they would have to charge me $200 to look at it and likely will not find the definitive reason for the misfire.…and I would be out $200.
In steps this forum- all the great advice from my issue is greatly appreciated! Special shout out to @RedZilla for putting all the info I needed in one post. Thank you!
I ordered the commercial version (-C) of the plug wires from Tasca and replaced all 8 today. You could easily see that my #2 wire was burned up. I took it out for some hard accelerations (which was fun) and could not get the issue to duplicate so it appears to be fixed!
I am not the most mechanical savvy individual so I’m a little on cloud nine that I fixed this myself.
Thanks for listening- have a great week!
Glad that was it!! Easy fix in the scheme of things and a known issue, especially on the 20-21 models.
Many of us carry a couple extra plug wires in the truck plus a code reader. If we ever have an issue plug the reader in, determine the cylinder, and inspect/replace the wire... I'm hoping with the "C" wires you don't have a repeat issue. :p
Hey @Maverick11 glad to know you got the problem solved. And it truly is the Forum community to thank for making this such a useful place to solve problems. Many have experienced the same issues prior to your request for help, and over several months and multiple owners going through the discovery process the solution boiled down to a simple fix. Many of us are just echoing what we've learned over time by working together here.
Unfortunately many Ford service centers are not really focused on helping customers as much as making money off their customers. This issue is no secret to Ford (they redesigned the new plug wires), and the service centers have to know more than we do. And yet they give unsuspecting owners the runaround and take them down this path of who knows where, charging an hourly rate while playing this game. It's not even a service department fix, but they won't direct you to the parts department for the solution. Really burns me when they work like this. Anyway, glad you are back up to speed!
First off, this has been discussed at length over the last couple years and the solutions and peoples' opinions of what the problem is, and what the TRUE fix is, kind of goes all over the place. Several have chosen to resort to after market plug wires. For many that didn't play out the best. For others it may have, don't really know. If you want reliable, go with the updated Ford plug wires and keep a handful of spares in the truck on a hard working trip. Also keep an OBD reader in the truck to help pinpoint the troubled cylinder.
This is a good OBD reader. Works with your phone with an app. Also doubles for doing ForeScan mods.
Ignition wire fail thread:
This is one of several threads on the topic of wire failures. It is pretty exhaustive on the topic, but there's even more threads to get more information, but you will find the best conclusions and solutions here. If you read widely you will experience much speculation that's unfounded and even a lot of experimentation that produced both good information and other failures.
Page 8, and others have specifics for the newest version of the plug wires. The part numbers can be confusing so you have to understand the details a little, but everything you need to know is in there.
Also below is a source for new plug wires that's reliable and cheap. Get you a set and an OBD reader to keep in the truck and you will be good to go.
Does this also work to change the different modes in the truck? New to forscan…
