19' F250 - Carli 2.5" / 4.5" Upgrade - Help!
RockyF250
Tremor Newbie
Colorado
First Responder
Firefighter
2019 F-250 6.7L
Hey there, I know this topic probably gets harped on a ton. I have read pretty much every Carli forum post on here, still in a position where I am not sure what to purchase! Figured i'd see if anyone, or if the expert @BLACKCHERRY could weigh in. Pics of my truck below for attention!
Little background, I live in the Rocky Mountains in CO. I am an avid dirt bike rider, and do a lot of hunting and tow a small 7x14 converted cargo camping trailer. Occasionally heavy stuff, but pretty rare enough to where bags are out of the question. I take my truck up and down lots of rocky trails, and washboard dirt roads in the middle of nowhere all through out the mountains. Based off of the forum posts it seems Pathfinder kit fits my needs the best, unless theres another recommendation? I have also had a little bit of death wobble issues on and off recently (Currently diagnosed I have a loose/bad drag link), and also have been wanting to improve the ride quality of my truck which has ultimately steered me into this direction. As all I have heard is very positive feedback about Carli.
Anyways here is what I am in-between on purchase wise, as my budget is not unlimited. I may need to buy majority of the kit as shown below and piece the rest together.
To fix death wobble, and make front end more robust/fix crappy drag link to be used with one of the options below: Apex Steering Upgrade (Not the ninja washer stuff, as I have heard bad experiences. I believe not they use pro-lock or another design that has been working well) Haven't decided on just the drag link or the full kit just yet. Will 100% be one or the other with the Carli purchase, unless there are better options.
Option #1: 2.5" Pathfinder Kit
(Excluding: Soft Ride Progressive Rear Leafs/all rear end upgrades, Radius Arms, Low-Mount Steering Stabilizer, Shackles)
Sway bar will be just end links for now with the rest of the torsion bar installed after rear end work. Ultimately will do rear leaf shackles and pinion shims with either kit once new rear leafs are thrown on.
Option #2: 4.5" Pathfinder Kit
Same exclusions as above, with readylift 5" rear block added to achieve level stance until rear leaf upgrade.
Now, are there any actual differences on/off-road between the 2.5 and 4.5 system? Or is it not noticeable, I read that @BLACKCHERRY stated the 4.5" has a flatter radius arm angle leading to better geometry. Is this something that you actually feel? Or notice in long term wear? Any other benefits? I will be running 37" Mickey Baja Boss ATs with a 17" wheel regardless of setup. No 38s as I need a 3-peak rated tire for the winters out here. Just trying to see if the 4.5 is worth the extra money, and will it be a real benefit on and off-road long term. Or if I'm just overthinking this and 2.5" will do the job just as well. I spend a lot of time off-road but these mountain trails are not like ripping through the desert, so I figured the pin-top was overkill.
