$1840 for LED headlights???
What did you do about fogs? I'm assuming you're also starting with halogens...
The right answer is to go with the Diode Dynamics SS3 Max, but they're not cheap at $520. The Pros are best bang for the buck at $300 for 85% of the max'es if you want to save some cash.
I opted for neither. I don't think the look of the LED pods work with my particular truck and what I envision it being, so I just got replacement LED bulbs from Diode Dynamics. It helps that DOT doesn't regulate fog lights, so replacing halogen bulbs with LED bulbs is perfectly legal. https://www.diodedynamics.com/h10-sl1-led-bulbs-pair.html
I’m going to add my .02 worth (just remember that it’s probably only worth .02). I ordered my Tremor as an xlt because I actually prefer cloth seats to leather (I really like the King Ranch but hate sunroofs).
Anyway, I will say that the stock halogen lights waaaaay underperform. My work vehicle is a 2020 Explorer with LED lights and they knock my Tremor out of the water.
If I had test drove an XLT at night, it probably would have pushed me up to a Lariat with LED lights.
With all of that being said, I would gladly upgrade to these lights if they actually perform well. I just don’t know if the black housing would look as good on an Oxford white XLT as they do the black one in the video.
I also wonder if Ford would use these as an excuse to void your warranty.
You're entitled to your opinion. I'm in a similar boat. For me, I like leather seats, but I don't care for many of the creature comforts other trim levels come with, especially the sunroof. I'd rather take that extra money saved and put it somewhere else more meaningful.
I totally agree with your assessment of the headlights. I though they'd be somewhat decent since they're quad halogen instead of dual halogen, but boy was I wrong. I could probably get better light by holding a candlestick out the driver window.
As for the warranty, legally they can't void it outright. The warranty on your OEM headlights won't apply anymore, obviously. Maybe they can void the harness or CANBUS warranty if it burns up due to a headlight defect. If that's the case, you'd probably want to take it up with Morimoto anyway. Otherwise, the entire warranty will still be in tact.
I find myself going back and forth with this very decision on a weekly basis. I really want better light output but every time I add them to cart I think man are you crazy $1800 for lights? I think I've about talked myself into them but then I sober up and go yup you are crazy. On a serious note I do think I'll be purchasing these in the coming weeks, the halogens are really subpar.
Worth the investment if you drive a lot at night or actually enjoy riding at nigh. Halogens should be band….there a joke!
The headlights arrived yesterday. I spent a very hot hour getting them setup and installed. I then spent a ton more time getting the LED fog bulbs and the grill guard installed. I managed to finish this morning after being a bit exhausted last night. Installing the headlights is no big deal, but it really helps to have the right tools with the LED fog bulbs and the grill guard.
I did a quick test last night, and the headlights are sure bright. I will report more after aiming and driving around later tonight.
Oh, as a note, the DRLs on the Morimotos work by tapping into fuse 16 in the main fuse box. That part was definitely not well thought out at all. The wire goes through the cover, but the cover is completely sealed from the elements, so I had to cut an opening on the cover to get the wire out. Hopefully, I managed to cut it in such a way that it won't get wet inside. I already see a lot of water spots on the fuse box cover due to some adventures I had in the past.
How can I tell if my Lariat model has LED headlights? Doesn't say anything on the window sticker that I can find.
I'm fairly certain the only way the Lariat would have LED headlights from the factory is if it has the black appearance package OR you have the ultimate package with the LED headlights added on top of that.
Someone correct me if I'm wrong.
Thanks. I do have both of those packages and looking at the build section on ford.com, it does say this includes LED for Lariat.
That's essentially my understanding - It's an optional addon requiring the Ultimate package - and they're included in the Black Appearance package
Also fair points, though I can't believe molds for plastic can be hundreds of thousands of $$. Is that true?
Ultimately, I guess the "yeah they're a bit brighter and yeah they look a little cooler" doesn't add up to $1840 for me.
Just out of curiosity - I pulled up Ford Dealer Parts Site - for OEM Halogen replacements = $758 per side. That's $1,517.26. So that's an extra $322 if someone wants to upgrade from halogen to DOT approved true LED headlights with a 5 year warranty. Ford OEM parts are primarily covered for 2yrs/24,000 miles.
I'd say that's not a bad price point at all for Morimotos when all is considered.
My one question I'd have: Are the LED headlights Ford has on the these trucks covered under the 3 year warranty? Or are they considered maintenance like bulbs are?
