17” x9” rim at +18 offset… will it fit?
In fact, I’m perfectly happy with stock tremor wheels with toyo at3 37/12.5/18s. It s a perfect combo which clears oem tremor suspension.
I'm surprised that the +40 rims worked with 37/12.5 tires, pretty cool.
Yep, it’s the best surprise with this new gen. And at least with the Toyo ATs the setup doesn’t look oversized in 37 either, for those not familiar they will likely look like oem tire size.
Context: MY23 F250 Tremor.
I had some KMC 17s, they didn't clear the brake calipers, so I returned them.
I think one person found some steelies that work (maybe it was @BroncoHooves ?) with 17" rims, but I punted and went to 18s +18 and gave up on the Baja Bosses (which wanted like 16oz(!) of balancing weight...)
MY23 no lift, 18s @ +18 works fine with 37s, no rubs and no trimming. OP looks to have a MY22, so not sure there.
Cheers,
-mox
17x8" wheels (not steelies though) at 0 offset on a 22 model year. And yes on the Baja Bosses. The worst one maybe took 11.5 oz.
lol thread number 5,000 on this exact topic. Probably thousands of people running that wheel spec. Go for it if that’s what you want. Post pics if you do!
stock tremor wheels are 18x8 +40 so if you go with a 17x9 +18 you are gaining 1" in total width and loosing ~3/4" spacing from the inside pushing the wheel out. so the inside sidewall of the tire even with the wider wheel is going to be in about the exact same place better for wheel bearing geometry and road manners. run that 17x9 +18 wheel with a set of 35" tires and you will be in business.
use this calculator to help you visualize the spacing https://tiresize.com/wheel-offset-calculator/
stock tremor wheels are 18x8 +44 so if you go with a 17x9 +18 you are gaining 1" in total width and loosing ~3/4" spacing from the inside pushing the wheel out. so the inside sidewall of the tire even with the wider wheel is going to be in about the exact same place better for wheel bearing geometry and road manners. run that 17x9 +18 wheel with a set of 35" tires and you will be in business.
Your calculation going from 18x8 to 17x9 is wrong numerically and also the tremor stock wheel is +40 not +44.
17x9 is 1" wider than a18x8 and thanks for the correction on the offset. I had it mixed up with the F_150 offset
It is not 1 inch wider and also not 3/4 inch inner either.
Here are the numbers:
Inner gain = 9mm =.354 inches
Outer gain = 35mm = 1.378 inches
I was looking at a set of Method 17x9, +18 offset wheels. Method site shows them incompatible with the the '23-up trucks. I called both Method and CJC. figured the manufacture and a company who puts wheels on these trucks daily would have the best answers.
Both companies told me that size Method wheel does not fit on the '23-up trucks. 🤷🏻‍♂️
