10R140 - Information - Problems - Aftermarket Solutions
I have no trouble with either of mine 7.3 or 6.7
I had no issues with the allison in the d max
I have many problems with all of the autos in my RAM Cummins trucks.
I have had problems with my 2000 Chevy 6.5 ( 1 year pre DMax)
After having transmissions rebuilt there are plenty of shops that can replace or rebuild a transmission but few who can really give you a solid reliable rebuild. I am fortunate and there are two shops in my town ( neither is a dealership).
Lots of Ford trucks out there so there are thousands of them on the road. I would be the failure rate is relatively low. You always here the bad news and the many out there with no issues are off your radar.
Good info to have in the back of the memory banks, thx.
Very well stated.......Completely Agree!!! The Dodge and Ram automatic transmissions have a horrible historical record. Independent transmission shops...both good and bad. Difficult to find good shops.
Thanks for the info, but not really surprising. The 10R140 was, and still is, my biggest concern for the longevity of this truck. There is just too many unknowns, and the Big 3 OEMs are too focused on 1/2 ton and car duty cycles to give me confidence they can get it right on a Class 7 rating.
Just and FYI, if you were to call Allison and ask what transmission to put in a Class 4 to 7 truck (up to 33,000 lb GVWR) with 1050 ft-lbs of input torque, they would push you to a 3000 series. Of note, the Duramax was originally released with a 1000 series clone.
But, I got 200,000 miles out of my 6L80 on my GMC without issue (however, with reduced maintenance intervals), and that is a notoriously bad transmission, so I'll drive this one the same and hopefully it breaks before the warranty expires or is proven to last.
There are solutions in the aftermarket with Next Gen Diesel.....but it cost money. The primary problem and weak part in the 10R140 is "cross leaking" in the lower valve body.
Regarding transmissions...newer trucks (2023+) of ALL makes will most likely not be any better. GM is dealing with a gigantic class action lawsuit on the 8L45E and 8L90 transmissions. Moreover, GM is having more than their share of problems with the 10L1000.
I had a 2019 F350 Lariat - 6.2L / 6R140, but sold it and ordered a 2022 F350 Lariat 7.3L Tremor, primarily because of the 7.3L gas engine...deep skirted block with all the good internal parts for reliability and durability. Personally, I will opt to do whatever is necessary to bullet proof the 10R140 in my truck. Furthermore, there is a good chance I will replace both axle tubes on the Dana M275 rear axle assembly.
Very good possibility the aftermarket will have a 6R140 transmission controller for a 7.3L / 6R140 application. However, the better solution will probably be to have a Next Gen Diesel custom built 10R140 transmission.
Torque Management.....could be. I am not sure. However, following is a partial "copy and paste" of my comment on another thread. It is about my own experience with a 5R110 behind the 6.0L diesel in a 2006 F350, in which I briefly describe the shifting characteristics between an OEM stock 5R110 and "street & tow" performance built 5R110. The difference is huge! BTS installed all the best available parts at the time with the exception of billet input and output shafts...did not need those for street and tow (the billet shafts are needed for racing and truck pulling competitions.
Several years ago, I had BTS in Arkansas (number 1 nationally known Ford transmission performance shop) build a 5R110 behind the 6.0L diesel in a 2006 F350 CC 4WD SRW 172. The truck was equipped with every Bullet Proof Diesel upgrade: FICM, water pump, oil to air engine oil cooler with remote oil filter, EGR cooler, aluminum radiator, ARP head studs, etc. Also had a PacBrake PXRB Exhaust Brake, SCT Programmer with BTS 70+ HP tow tune (had the 475 RWHP tune, but never tried it out). The truck was a towing machine. I used the truck to pull gooseneck flat bed and gooseneck horse trailers.
There was NOTHING wrong with the 5R110 in my 2006 F350, but after talking to different people, I decided I wanted some performance parts in the 5R110. Besides, I was hauling horses to 18 different states, 3 to 4 weekends every month for six months every year for several years. Anyway, the point is, the transmission shifted OK before the build and indescribably better after the build. BTS installed a Stallion torque converter from Precision Industries, performance clutches, etc. The difference in drivability and performance was (is) astounding...truly "night and day". After the BTS build, the 5R110 transmission would shift EXTREMELY smooth from a NORMAL launch. If I got on the accelerator MODERATE or HEAVY...the 5R110 would shift fast / quick and hard. The owner of BTS (Brian) said that is exactly what it is suppose to do.
However, I do not take that as "positive statement" in any way, shape or form as a comparison, correlation or connection pertaining to the described 5R110 shifting above...or to the similar shifting experienced by the owners of trucks with 10R140 and stock OEM parts. Two completely different transmissions. On top of that, Ford or GM is NOT going to spend extra $,$$$.$$ money on high quality parts. They want the transmissions to survive the warranty period.
I personally loved the 5spd in my '05 6.0l (I know it did not have 1,000 lbs). Honestly kind of miss that truck sometimes. Had it almost 100,000/10yrs with few problems, until my last year of ownership. Other than my '09 GT500, probably one of the best build quality Fords I've owned. Drove that truck for 8 years on 1 warranty claim and a rear brake caliber/ABS sensor (Normal maintenance of course). I also really liked my '15 6.7 with the 6 spd. Had no complaints other than torque management, however it was not as intrusive as my Tremor.
You can definitely feel torque management, which I personally just don't like. For me it kinds of ruins the driving experience. Just like the traction control in my GT500. I can not drive around with it on. If it detects any wheel slip, it immediately cuts power. For example just hitting some sand or making a hard right turn.
Finally I don't dislike the 10 spd, I just think there is some room with improvement, similar with the 6spd when it first came out.
Incidentally, I noticed harsh shifting *occasionally* on my 2020 6.7L at around 15k mi, and mentioned it to the dealership that was doing an oil change at the time. It would sometimes jerk around between 3 and 5, and skip 8 altogether.
Brought it back later and they ran some tests and said it qualified for service to be done under warranty where I believe they replaced the valve body. They said they ran it through a bunch of tests and sure enough it failed like 1 out of 20 times, but that was enough.
They replaced it, and aside from some weirdness during the very first day (they said it was still "learning"), it's been fine ever since.
Sounds familiar...read on the internet about this part failure. The Lower Valve Body (LVB) is susceptible to a problem known as "cross leaking". The LVB and the Fluid Pump are known for damage caused by clutch materials, shavings and steel particulates from the inferior torque converter and clutch stack ups end up running through the Fluid Pump and LVB. Therefore, both components...the Fluid Pump and the LVB are destined to have a shortened lifespan and experience "premature death" in an OEM 10R140 transmission.
Powerstroke
my powerstroke shifted good. every now and then a jerk from 2nd to 3rd, only did it if i eased into the throttle otherwise it would just skip shift and feel fine.
I had a 2019 F350 Lariat - 6.2L / 6R140, but sold it and ordered a 2022 F350 Lariat 7.3L Tremor, primarily because of the 7.3L gas engine...deep skirted block with all the good internal parts for reliability and durability. Personally, I will opt to do whatever is necessary to bullet proof the 10R140 in my truck. Furthermore, there is a good chance I will replace both axle tubes on the Dana M75 rear axle assembly.
what would the controller off the 6R140 do? I'm assuming it doesn't matter that its going from a 6spd to a 10spd? Why replace the axle tubes on the M75?
And when is someone going to start a thread called "the amazing bullet proof million mile 2022 7.3 f350 Tremor" since i just sold my 2020 diesel to get one?
MoKan on his Number 23 post --------> Quote - "The 10R140 was, and still is, my biggest concern for the longevity of this truck." Regarding 2020+ Ford Super Duty trucks, I could not have said it better and completely agree with his statement!
Transmission Controllers are designed for specific transmissions. BTW, it has become apparent to me from reading several comments from a few forums, most people are not aware the 10R140 behind the 6.7L PSD is controlled by the Transmission Control Module (TCM), while the 10R140(G) behind the 7.3L Godzilla is controlled by the Powertrain Control Module (PCM)...the 7.3L does not have a TCM. In other words, the 6.7L PSD has both the PCM and TCM...and the 7.3L Godzilla only has the PCM.
Currently there are no OEM 6R140 controllers for the 7.3L Godzilla application. I talked to a shop in Florida a few weeks ago about various transmissions, but primarily the 6R140 and applicable aftermarket controllers for the 7.3L Godzilla engine, for application in older Super Duty trucks (the preferred model year 2005-2007 trucks) and Excursions.
He told me the first priority in the aftermarket is to provide transmission controllers for crate 7.3L Godzilla engines, mostly to be used in Fox body Mustangs for racing applications. He did recognize the probable market potential for other applications, most notably the truck applications I mentioned during our conversation.
I will be following up with the shop in Florida and a couple of other sources to keep tabs on any news of a 6R140 transmission controller (OEM and Aftermarket) since I would like to have a 7.3L Godzilla backed by a 6R140 in a 2005-2007 Ford Super Duty.
I had a typo (Dana M75) regarding the Dana rear axle assembly on a previous post. I have corrected that to Dana M275. The early Dana M275 axle tubes have various wall thickness across the length of the tubes...thinner under the rear leaf spring perches. See Ford TSB - 21S31.
I am still in the process of conducting additional research on the Dana M275 axle tubes. I do know that 6.7L PSD trucks built May 16, 2021 and later will have the revised "full thickness" tubes. However, it is unclear if the new axle tubes are being used in 7.3L Godzilla applications or if Ford is still trying to save $5.00 - $10.00 per set of axle tubes and using the inferior tubes.
That small amount of money multiplied by several hundred thousand trucks will equate to millions of dollars. ALL the manufacturers want to keep costs down to be competitive and increase profits...they simply want the integral parts of the major components to survive through the warranty period.
There are a few million mile 7.3L PSD and 6.7L PSD trucks now. Look up PowerStroke Tech Talk w/ARod on YouTube. ARod is a Ford Service Technician and has NUMEROUS videos about the 6.7L PSD and has a couple of videos with million mile 6.7L PSD. One truck actually has 939,139 miles and the other truck is around 1.3M miles.
ARod has identified several weak points regarding "surrounding operating parts and systems" of the 6.7L PSD. If I had a 6.7L PSD, I would definitely be doing most all of the upgrades ARod has suggested in his videos. The CP4 seems to be the biggest problem...IMO it is a ticking time bomb.
Bill Hewitt is another well known PowerStroke Diesel Technician. I found an article on his website particularly interesting. I would venture to say there will be some butt hurt people who own 6.7L PSD trucks who will completely disagree, but Bill does state some undeniable facts regarding each of the PSD engines (7.3L; 6.0L; 6.4L; and 6.7L).
The article in Post Number 2 covers your "skip gear" description and quite a bit more. I found the A-F clutch assemblies and accompanying shift solenoids especially interesting.
There are a few million mile 7.3L PSD and 6.7L PSD trucks now. Look up PowerStroke Tech Talk w/ARod on YouTube. ARod is a Ford Service Technician and has NUMEROUS videos ab out the 6.7L PSD and has a couple of videos with million mile 6.7L PSD. One truck actually has 939,139 miles and the other truck is around 1.3M miles.
That was a big factor in me switching to the 7.3 was the cp4, and not really needing a diesel at all. Didn't know that about the 275 tubes. i read that about the 6R140 controller in the article. I guess they are wanting the controller to be able to put a 6r140 in the truck? When I first read it I thought you were saying just put the 6 controller on a 10. That transmission rebuild is going to take all my supercharger money
I see you are in Big Sky Country! I have a Montana business...LLC. No, not a 6 controller on a 10 transmission...that will not work. I am not sure if using a 6R140 transmission and controller to use behind a 2020+ Ford Super Duty 6.7L or 7.3L is legal in F250 to F550 trucks. There are federal regulations on engine swaps, but not sure if transmissions swaps are regulated. Ford is building 2020+ F650 and F750 trucks...both with 6.7L diesel and 7.3L gas...and both backed by the 6R140 transmission. Keep in mind these trucks are going to have much lower gear ratios in the differentials.
I am not sure if the applicable TCM for 6.7L and PCM for 7.3L would work in the F550 down to F250 trucks. Not sure how or if the transmission "learning process" would work. There are and will be people wanting to put the new 7.3L gas engine backed by the 6R140 transmission into an older Ford Super Duty, probably 1999-2007 MY trucks.
Federal Regulations (Laws) provide guidance in reference to "engine swapping" (engine switching). It has been several years since I read those regulations, but basically, it is illegal to place and "older engine" in a newer model vehicle. To say it another way, the engine being swapped into the vehicle must be of the same production year or more recent production year than the vehicle. OK for new technology in older vehicle, but not OK for old technology in newer vehicle.
For example, many Ford truck owners have swapped the 5.9L Cummins 24V diesel engine into 2007 and older Ford Super Duty and Heavy Duty trucks. The 5.9L Cummins 12V diesel engine has been placed into older trucks. It is not legal to install a 5.9L Cummins 12V diesel engine into a 2005 Ford Super Duty. I do not know if these same regulations address or cover other drivetrain components like transmissions. The reason being is related to fuel efficiency and the 10R140 is more fuel efficient than the 6R140. Could be a big problem for areas requiring any emissions testing prior to plate / tag renewal.
Information below is OFF TOPIC but interesting:
Destroked in Colorado started it all. They now only supply parts. Conversions are done by GOS Performance in Livingston MT and Fummins in Kalispell MT. If I had the need for a diesel truck, I would get the 5.9L Cummins 24V from Industrial Injection in Utah or CPP Diesel in Pennsylvania and put it in a 2005-2007 Ford Super Duty.
First, I am here to learn, gain knowledge and hopefully share useful information regarding Ford Super Duty trucks, most particularly the trucks equipped with the Tremor Package. Second, I have noticed more than a few threads in reference to comments, statements, issues, problems, questions and concerns regarding the Ford 10R140 automatic transmission.
After a fair amount of research and reading on the internet, supplemented by watching some YouTube videos, it appears the 10R140 transmission has the potential to truly be the "Achilles Heel" (a weakness in spite of overall strength) in Ford Super Duty trucks. Likewise the 10L1000 transmission is already proving to have the same potential in both Chevrolet and GMC trucks. Enter the aftermarket with the objective of removing the 'weakness' of the Achilles Heel. Properly equipped with street / tow performance internal parts, the 10R140 should provide good reliability and durability for a Ford Super Duty truck.
Prior to showing any information on the 10R140, a little history might be in order. Back track 20+ years, to the 4R100 behind the 7.3L Powerstroke diesel. The 4R100 had a stout structure AND weak internal components and parts. HOWEVER, the 4R100 built by BTS in Arkansas would later live a life as a super strong performance transmission behind the 5.9L Cummins in "truck pulling" and "diesel pickup racing" (also behind 6.0L Powerstroke using the 4R100 bell housing from the 6.8L V10 gas - same bolt pattern as 6.0L diesel). Although I am not an expert, I can tell you the 10R140 will not experience the same glorious life that was lived by the 4R100. The 6R140 would come much closer to that accomplishment. Brian at BTS said the 6R140 has the best internal parts of any transmission he has ever seen roll off the assembly line...including all of the GM (Allison) transmissions. There are performance upgrades for the 6R140. Even though the 6R140 is stout in stock OEM form, the performance upgrades will provide a "night and day" difference in shifting, reliability and durability.
The TAKE from the above paragraph is: The last four Ford transmissions all have a "strong robust structure", but for the most part, only two, the 5R110 and the 6R140 rolled off the assembly line with good strong OEM internal components and parts. This leaves the 4R100 and 10R140 coming off the assembly line with weak internal components and parts. However, the aftermarket responded with high quality parts for the 4R100, and properly built, it is a "superman of transmissions". Even though the 10R140 probably will never achieve the same performance accolades of the 4R100, the aftermarket will respond (has responded) in a very positive way with performance parts to offer the reliability and durability for street and tow performance all of us Ford Super Duty truck owners desire and expect. There will be a "night and day" difference in performance with improved reliability and durability between a stock OEM 10R140 compared to a custom built street / tow performance 10R140.
Below is brief synopsis of information I have gathered from internet research and reading about the Ford 10R140 and GM 10L1000 transmissions. Some of the following points may be obvious to some people.
1. robust structure, yet has complex design and function
2. primary problem and weak component is "cross leaking" in the lower valve body
3. several other weak internal components and parts (the list is fairly extensive)
4. 10R140 behind the 6.7L diesel - controlled by TCM (Transmission Control Module)
5. 10R140 behind the 7.3L gas - controlled by the *PCM* (Power Control Module)
*PCM - term used by Ford* / ECM (Engine Control Module) - term used by Dodge (Ram)
NOTE: The GREAT NEWS is with the aftermarket. Currently, I know of one company (source) that supplies performance components and parts. Robust Structure + Weak Internal Parts = $,$$$,$$$.$$ for a Performance Transmission Shop. But, the BAD NEWS is there are a few technically difficult obstacles which will likely curb the number of quality shops with competent technicians who can install the street / tow performance upgrades for the Ford 10R140 and GM 10L1000.
How much will upgrades and or a custom built street / tow performance 10R140 cost?
Stay Tuned.......
Just watched a video guy is talking about aftermarket parts for these transmissions. Basically there is little to no room in the case. Any aftermarket parts would be VERY expensive. If you NEED to upgrade the power of the engine, probably best to use the 6 speeds.
Stock 10R has a fairly recent tsb for the CDF DRUM issues that replace with new design to prevent bushing slipping and ALL the issues people having. 10L isn't as robust as 10R and WILL fail sooner and more often.
GL
