Just got done weighing the truck and camper. Very interesting results.
Truck:
I expected the truck to weigh around 7460 lbs. Or basically 11,300 GVWR - 3840 payload = 7460.
Trucks actual weight was 7520. Front is 4260 & rear was 3260. I actually though it would be heavier.
But it makes perfect sense, since I've added a few things.
Truck plus NL 8-11:
Camper is listed as 2800 lbs dry.
Camper actual weight was 3360 lbs - WTF???
Camper was essentially empty, I just bought it.
It did have some winterizing antifreeze in the lines and some in the tanks.
But nothing that explains it weighing about 500 lbs more than it should.
Conclusion:
1. The extra weight of the camper only leaves me 500 lbs capacity instead of the 1000 lbs I was expecting.
2. Front axle got 240 lbs lighter with the camper. Went 4260 down to 4020.
3. Rear axle is almost at maxed out 6860 with the camper. Rear GAWR is 6950. Only 90 lbs payload left.
4. Most people with truck campers are probably over GVWR.
Raw numbers for people like me who geek out on that stuff.
View attachment 206390View attachment 206391
