Transmission Shift Issue
buckeyefanaddict
Tremor Newbie
Tampa
2021 F250 Tremor
F250 2021 with 600 miles. Truck motor working at higher RPM's and not shifting smoothly. Anyone heard of this or have a similar issue?
ECHO-24
Founding Member
Lakebay, Washington
2020 F350 Tremor
1973 Jeep CJ5
Take it back to the dealer.
Never mind the posting, your truck is out of that date range. But take it to the dealer
DwnSth
Founding Member
Texas
F250 tremor 2021
7.3?
ECHO-24
Founding Member
Lakebay, Washington
2020 F350 Tremor
1973 Jeep CJ5
All trucks that fall in this date range, not just the 7.3.
AFFECTED VEHICLES Vehicle Model Year Assembly Plant Build Dates Super Duty F250-F600 2020 Kentucky Truck 28-Feb-2019 through 10-Aug-2020
Ohio Assembly 03-Apr-2019 through 31-Jul-2020
DwnSth
Founding Member
Texas
F250 tremor 2021
Get a forescan, will tell u all ur codes!
Ginja
Tremor Fan
Massachusetts
When was your production date? TBH, my trucks falls out of that range but something ain't right with mine ether.
Edit: to clarify, Occassionly, I feel like coming in and out of 3rd there is a kick back kind of, but I can never replicate it.
LT75
Founding Member
Saint Charles, IL.
2021 F250 Tremor lithium grey
There is a lag between those gears if you do not hit the Excelerator hard enough. It’s like the truck doesn’t like to be driven in eco-mode. Lol. Honestly though. I’ve noticed when I’m easy on the gas pedal it does it more. But if I give it a good amount of acceleration and the trans shifts fine
Ginja
Tremor Fan
Massachusetts
Yea that's it. So that's normal? Or just a "glitch" that no one really cares about.
LT75
Founding Member
Saint Charles, IL.
I was hoping it would get better after the break in period. I have 1000 miles on mine. I bought the bank’s pedal monster to see if that helps.
thevol
GA
7.3 XLT Tremor
The low speed behavior when empty is not great on the 7.3. Mine does perfect when it has a load on it so I assume that is where they spent most of their time testing and tweaking. Just donesnt feel like this truck wants to be empty tooling around town.
CityHunter
Tremor Buff
TX
‘21 Tremor 6.7
I haven't experienced this with the 6.7. I'd say this probably goes beyond a quirk, and should be looked at by a dealership. Do you happen to have any videos of the behavior? Hopefully it's something that can be reset/reprogrammed.
DrinkingInTheWoods
Norcal
Navy Vet
2020 tremor 7.5l
+2 on the truck driving better under load. Crawling through my neighborhood is always unsatisfying the way it shifts.
thevol
GA
7.3 XLT Tremor
Same here and I think the diesels do better because they are heavier and the power comes on differently with the turbo, could even be the way the torque management is limiting power, dunno but there are definitely more complaints with the 7.3, its touchy off idle and messes with the trans programming.
