Lurking Class
Tremor Fanatic
- Joined
- Feb 28, 2020
- Messages
- 148
- Reaction Points
- 303
- Location
- Chino CA
- Current Ride
- 2020 Ford F-250 Tremor 7.3L
Hello all,
Tonight I went to move my truck around. I have a 2020 Tremor with the 7.3 L with over 27k on the clock. I started the truck with the remote start like I most of the time. Jumped in and insert the key to turn the truck on. Moved it around about 100’. Put it in park and when I turned it off it stayed running for about 2-3 seconds. About 10-15 seconds after it turned off, I went to start it again and it sounded like the truck was trying to start and when it did the starter sounded like it ran for 2-3 second. The RPMs went to a thousand and then idol down to where it normally is. Just had the oil changed at Ford and had about 500 miles on it when this happened. I let the truck sit for 2 minutes and started it again. The truck started normal. It’s just weird what it did. Not sure if it was a one time deal of start of a bigger problem. Any guesses?
