FOR SALE Sold: Kicker Key 200.4 and 500.1
nominion
Tremor Buff
PA
2021 F350 CCSB 4x4 7.3L 4.30
I installed these in my 2021 F350 for approximately 2 years. I've recently upgraded and no longer need these. Both are in good working condition as they were mounted to an amp rack behind my rear seat. They both need the tune wiped as I forgot to do that prior to removing them.
Kicker Key 200.4
- Includes the power and speaker wiring harnesses and the microphone used for tuning.
- $206 (includes 3% PayPal fee) OBO shipped anywhere in the lower 48.
Kicker 500.1
- Includes the speaker wiring harnesses.
- Includes the Sounds Good Stereo factory integration harness needed if you plan to keep the factory amp/DSP.
- Includes the Kicker CXARC remote volume control and the cable.
- $257 (includes 3% PayPal fee) OBO shipped anywhere in the lower 48.
Combo deal price: $437 (includes 3% PayPal fee) OBO shipped anywhere in the lower 48.
Payment via PayPal (goods and services) is preferred, but if you'd like to avoid the 3% charge, PayPay Friends and Family is good and I will adjust the price accordingly.
Bump. Make me an offer as I'd like to see these put to good use.
Out of curiosity, what were you running with these?
Does the sounds good harness have the bass roll off like factory?
The 200.4 was feeding a pair of JL Audio C1-650 components in the front and a pair of C1-650x coax in the rear.
The 500.1 was feeding a JL Audio 10W1v3-2 sub. The 500.1 has an integrated DSP that fixes the base roll-off at higher volumes. The harness makes it very simple to integrate, without using something like the Zen A2B and without having to tap in to any wiring.
I started with replacing the factory sub and added the 500.1 with the harness and I kept the factory amp/DSP. This really helped the lack of low end. I then had the great idea to replace the door speakers, which started me down the path of eventually going with the 200.4 and a Zen A2B.
Recently, I decided to do a a 2 way active setup in the front using a JL Audio vx700/5i and Audiofrog GB15 and GB60s while keeping the JL Audio sub, so I no longer require the Kicker gear.
Interested in the 200. I already have the 500 running an 8" comp rt that replaced the factory sub. How did you wire up the 200?
@joshthedoc is interested in both the 200.4 and the 500.1. If that for some reason doesn't work out, I will everyone else know.
Since my truck has the B&O, I used the PAC APH-FD02 to connect the Zen A2B and the Kicker 200.4 to the factory wiring, no splicing required.
