Today Woot.com has 33% off Dewalt Self Level 3-Beam Laser Level. This normally retails for $179.99 and today you can grab one for $119.99
The DW083K 3 Beam Laser Pointer includes a single lever power switch that locks the pendulum in the off position for added durability and the built-in magnetic pivoting bracket mounts easily on metal surfaces.
- Self-leveling point laser is accurate to 1/4" @ 100'
- Single lever power switch locks pendulum in the off position
- Built-in magnetic pivoting bracket mounts easily on metal surfaces
- Integrated track clearance enables users for fast and accurate bottom and top track installation
- Focused laser beam keeps dot size small over longer distances for improved accuracy and visibility
- Overmolded housing helps maintain calibration under job-site conditions
- IP54 Debris/Water Resistance
