Rokblokz mud flaps do not fit FYI
Wrangler98
Maine
Current Rides #1
2021 tremor 6.7
Installed Rokblokz step back flaps today, they do not work with our fender molding. I tried every modification possible.
looks like the ones on the website fit fine and it looks like they have the fender molding as well.
if the upper piece is aluminum it might need to be "massaged" to fit.
They absolutely do fit. You must have missed some steps. It does require drilling, zero cutting. I have front and back they work amazing and couldn't be more solid.
My fronts fit great, the rears did not. You have a pic from the side of your rears? It wouldn’t sit snug against fly fender molding
I had to drill out the existing 2 holes on the fronts. The rears required 2 holes also to be drilled. The directions are pretty clear on that. I even added the extra spacer behind the rear flap, just wouldn’t square up.
I would totally agree about not being perfectly flush compared to the front. When the mounting hardware is tightened it pulls the outside flat a little. No noticeable consequence I can find. Already beaten on them and I can't imagine anything holding up better
View attachment 31618I would totally agree about not being perfectly flush compared to the front. When the mounting hardware is tightened it pulls the outside flat a little. No noticeable consequence I can find. Already beaten on them and I can't imagine anything holding up better
Ok thanks, that’s exactly how mine fit, not acceptable if you ask me for 300 dollars
FWIW, I installed the non-kickback Rokblokz last night. It takes a little bit of effort figuring out how to line things up, but the fit is fine. I can understand the desire for extra clearance, but if you are staying near stock height and tire size I don't think you'll have a problem.
If these were expensive, don't look at the gatorbacks...
Did you take any pics?
