NEO Motorsport Garage Tremor Build
NEO Garage
Tremor Fanatic
TOTM Winner
North Royalton, Ohio
2020 F-350 Tremor
2019 Ford Raptor
Hey everyone, figured having a thread on here to track the build and just keep track of what we’ve done to it would be a good idea.
2020 Tremor 6.7L
Star White Lariat Sport
Eibach Pro-Truck Level
ReadyLift Adjustable Track Bar
Engine Tune & Exhaust
37x12.50x18 Falken AT3W Tires
MBRP 4” DPF-Back Exhaust (coming soon)
Raceline 935BZ 18x9 -12mm
BAKFlip MX4 Tonneau Cover
0913CAAC-CE07-47BF-A693-A48AC188FE17.jpeg6C9870C7-C8F2-4561-9904-D2BFC58727C7.jpeg73CD672A-3D2B-4362-9A4F-48CBCD62935A.jpeg
The build looks great! I'll be interested to see what the MBRP exhaust looks like!
It’ll be this one but with a black tip. It sucks MBRP doesn’t have a kit that includes a black tip outside of their “black” series.
Ill be following this build for sure. Going be going down the same route on a lot of the parts selection.
Yes sir, they fit fine, but do rub the radius arms at full lock. Having a true 12.5 wide tire makes the truck feel so much more steady.
Absolutely agree. The wider tires made the truck feel so much more stable.
Looking good! What kind of difference did you notice after the track bar was installed?
AMP Extreme Power Steps installed, these things are sturdy and drop down a good amount. No longer jumping in and out!
Looks great. Haven’t seen a lot of lifted white Tremors with the lariat sport package. I have the same truck. Lift/Wheels/Tires will likely go on next spring. Have a lot of work mileage coming up in the next 6-8 months so might as well put the miles on the stockers.
@NEO Garage, your truck looks great! I have ordered the same color F350 Tremor w/black appearance pkg.
Is your tire rubbing issue to the point you're going to remedy it, or is it really not much of an issue? Will new rim offset help with tire rubbing? I ask because I'll likely go with the same setup.
Thanks for the pics & info.
This is my first white vehicle, I love it! The color pops well and no chrome trim is the best.
Let me know when you’re ready for the mods, I’ll take care of ya(y)
It’s not bad. It’s only at full lock on the radius arm, no where else. It doesn’t bother me really as much as I thought it would, but I still plan to get a new wheel set up regardless if it rubbed or not.
A more aggressive offset (like +15-20) would put you in a good sweet spot for no rubbing issues anywhere.
I’d be happy to get you hooked up with some wheels and all the extras when you’re ready!
Finally found some personal time to install the new Diode Dynamics SSC2 lights into the factory fog light pockets. Now to find the time to wire them in.. lol
SAE street legal and 2900 lumens! Not too bad
Found time to wire in the lights and also get the rear SSC2 reverse lights installed!
Now finally a big upgrade. I like them for the most part, we will review again when the suns up!
