Method 305 NV HD 18x9, 8-170 + Nitto-ridge-grappler 35x12.5x18 + Spare
johernan
Tremor Newbie
Kirklannd
Army Ret.
F250 PLAT TREMOR
First Responder
NO
Hi, I am interested buying this wheels + tires kit
Wheels: method 305 NV HD 18x9, 8-170, +18 offset (HD version 4500lb load capacity)
Tires: Nitto-ridge-grappler 35x12.5x18
But before I do I would appreciate if anyone could help me with some questions I have.
  1. What TPMS sensors to use on them, any recommendations?
  2. Any rubbing on stock Tremor suspension with this sizes?
  3. Would a 5th wheel/tire combo with TPMS fit on the spare location?
  4. Anything else I should be worrying about before ordering?
  5. Would I need to change the tire pressure settings on the Tremor using FORscan.
Thanks a lot for your help.
1: use the stock sensors?
2: probably on full lock reverse with that offset.
3: yes, it would just hang lower relative to the stock tires. I have the 5th wheel prep on my truck with 35's.
4: mileage hit maybe? I run the same wheel size and offset with 34.8" X 11.2" with no rubbing.
5: Depends on what PSI you plan to run. I used FORScan to change other settings but was able to air mine down to 60 psi with no warning lights prior to utilizing FORscan.
Watching. I'm also interested in TPMS recommendations. Planning on selling the stock wheel/tire/TPMS right off of the truck. Not able to reuse original TPMS as a result.
4 for $50ish on ebay. Or ask @fordguy74656 if he has any to spare.
