Manual shifting
I thought hitting the up/down shift button when in drive locks out the higher gears. When in drive if you hit the down shift button the "10" will go away, then hit again and "9" goes away, etc. to get them back hit the up shift button the gears will come back.
Correct you can lock it out, but can not manually shift it up unless it would normally shift to an higher gear naturally.
Yeah, the gear lockout feature is what GM called MANUAL mode on my 2009 GMC. Running the Tremor in manual mode makes it as close as possible without putting the truck in a bad spot (like trying to take off in tenth gear when stopped)
That YouTube clown “danger industries” made a “paddle shifter”. Which he sells.
I don’t know if anyone is familiar with him, but every video is a horrible accident waiting to happen
