Load binder ends?
oops
Tremor Aficionado
CA
I'm looking to customize my load binders to be able to connect directly to D-Ring's by adding an “end” that has a Clevis Sling Hook / Slip Hook.
Anybody know where I can buy load binder “ends”, or whatever something like this is called:
This photo is from Laclede Chain who has a configurator for custom load binders. But I just want new ends for existing load binders.
For more context, I currently have some Peerless Quik Binder's:
And I want to covert the “ends” to be like these binders:
But I'd rather not buy all new binders just to harvest the “ends”.
Unfortunately my Google skills are failing me. I'm hoping I just don't know the proper nomenclature?
I'm looking to customize my load binders to be able to connect directly to D-Ring's by adding an “end” that has a Clevis Sling Hook.
I wasn't able to find the ends by themselves either. Wonder if you can just build the end you want yourself using a hammerlock or equivalent rated/forged connector and the hook you want after cutting off the old one.
Side note: I saw, on someone's YouTube video, the speed binders where you can use a cordless impact wrench on, and they look sweet!
I wasn't able to find the ends by themselves either. Wonder if you can just build the end you want yourself using a hammerlock or equivalent rated/forged connector and the hook you want.
Good idea.
Side note, I saw the speed binders where you can use a cordless impact wrench on someone's youtube video and they look sweet!
Those are neat, but I think they'd only be worthwhile if you're regularly tightening MANY binders (like on a semi-trailer.) I saw some speed tests where it really only saves a second or so per binder (which is lost in time finding your impact wrench.) The big benefit seems to be saving your wrists.
If I had endless money (and room to store all of the things) I'd probably go for the Ancra EZ Binder for my use case (rarely using more than 4 binders at a time.)
Good idea.
Those ones are really nice too!
Here's the video segment of the ones I saw yesterday:
OK I think you're on to the better direction to go in.
This way I'll be able to make a “sling” on one end while also leaving the grab hook on for versatility. e.g.
Awesome. Would a D ring shackle be more versatile for the one end instead of the clevis slip hook with thin safety latch?
I suppose I could also just pony up for pre-made chain slings to replace my transport chains.
Would work great for the excavator, but I'd need some extra anchor points on other equipment. 🤔
And this is why my trailer boxes are full of crap. 😂
This topic is outside my wheelhouse lol, but Tow Piglet (hot shot driver and business owner) linked to the site he buys his equipment from. Figured I would share a link to it in case it has what you’re looking for:
Try here. https://www.uscargocontrol.com/collections/Rigging-Supplies-Hardware
