Zachonthat
Tremor Newbie
Is it possible to use Forscan to make WiFi stay on and not go into battery save mode after 30 mins? I’m sure it’s a BCM thing. I also know the BMS shed timer needs to be disabled.
Note: This feature currently requires accessing the site using the built-in Safari browser.
you can delay the battery save mode but can't have wifi stay on, all night wish i couldIs it possible to use Forscan to make WiFi stay on and not go into battery save mode after 30 mins? I’m sure it’s a BCM thing. I also know the BMS shed timer needs to be disabled.
Delay it by how much??you can delay the battery save mode but can't have wifi stay on, all night wish i could
i believe i set mine to 30 mins or so , i need to go back into forscan and find the settings againDelay it by how much??
What do you think the max is?i believe i set mine to 30 mins or so , i need to go back into forscan and find the settings again
