Note: This feature currently requires accessing the site using the built-in Safari browser.
There are several good treads on FORScan on the forum. Here is a link that should answer your questions and get you started.I definitely need to make some changes to my tremor. I see there are two different cables or one that hooks up to the cell phone. which one is best which cable should I get?
thanks
If I only have apple iOS then there is only one choice for me.
thanks this is what I needed.
Can iOS make changes or is windows best. Am I gonna need a windows computer?There are several good treads on FORScan on the forum. Here is a link that should answer your questions and get you started.
You will need Windows. Several on the forum, me included, are Mac users that got a low end Windows laptop for this. You don't need anything fancy or much computing power.Can iOS make changes or is windows best. Am I gonna need a windows computer?
Thanks, my head is ready to explode trying to figure this out. I was starting to figure it out but you made it clear for me.You will need Windows. Several on the forum, me included, are Mac users that got a low end Windows laptop for this. You don't need anything fancy or much computing power.
If you haven't seen it yet, the following link will take you to a good primer to get you started. Go slow, start with Plain English modules until you get comfortable with it. Make one change at a time and record original values in case something unexpected happens. Then you can undo the change. Search FORScan on youtube, there are some good videos. Good luck.Thanks, my head is ready to explode trying to figure this out. I was starting to figure it out but you made it clear for me.
Thanks
