Finally got around to using forscan
7.3Tremor
Tremor of the Month 🏆
Texas
USAF
2020 F-350 Tremor Lariat Ultimate Sport Silver Spruce
First Responder
Houston Fire
Super easy to update settings and I’m no computer guy at all.
Glad you got it figured out and didn't run into any issues. What all did you change, I see the splash screen and assuming door ajar chime? Anything else you wanted to do but couldn't figure out?
I deleted all the dinging and honking, Bambi mode, tpms lowered, splash screen, temps above gauges, drl 100%. No issues, I did have to return truck to stock before using forscan, then reloaded tune after all changes were done.
I did my 6.7 right away, I need to re up with Forscan and plug into my 7.3 and do some work.
Need that honk gone!!!!!!!
Its really easy to use and lots of nice touches you can put on your Tremor.
Oh yes dark mode!
My 2020 didn’t give me the option for dark mode and I looked for it. From my very hasty research is that it is not available any longer, you basically have to turn lights off separately in the module. I left it alone and went to something else.
I dont have forscan yet, but I saw it on there a few months ago when I was looking at it. If its not available, that is disappointing. I will research a little more too. What route did you go?
I just left lights as normal except Bambi mode.
just hit mine with the forscan yesterday. Ditched the double honk set up Bambi but had no luck with temps above the gauges.
