I have a '22 250 with the 7.3L continually getting a evap code.
I've been to my local dealer 4 times and still no solution. I bought the truck about June of '22 with about 1800 miles on it and the check gas cap message would come on the dash, checking the cap would do nothing. Finally that message stopped appearing and the check engine light came on due to the evap leak.
The truck has about 7200 miles currently with 4 trips to the dealer when I could work it into both schedule and theirs.
first trip they stated the filler neck was dirty and needed cleaned. Cleaned the neck and still have issues.
Second trip they stated the evap purge valve was bad and needed replaced, replaced the purge valve and 2 weeks later the CEL was back,
Third trip they tried a new cap and stated the filler neck needs replaced.
Fourth trip replaced the filler neck and cap again and still has a evap leak coming from the seal of the cap to the neck.
They removed the cap and taped the neck shut and ran a vacuum test and it passed, put the cap on and it fails.
They have not seen this issue before, they've contacted ford and the filler neck was a updated part number but the cap is still supposedly correct.
They opened a hotline case with ford to try and resolve and are going to try a few other oem caps to see if it solves the issues.
Has anyone else experienced anything like this?
I'm looking for possible other examples of the issue and what may have solved it?
Thanks.
Thanks.
