Tucked up under the front bumper. You can access it in the middle space where the winch/front license plate bracket is.Where is the engine block heater cord hidden ? Thanks in advance
This is not where it is located.check the passenger side of the front bumper
Found it. Man they really make it difficult to find.Tucked up under the front bumper. You can access it in the middle space where the winch/front license plate bracket is.
on mine 6.7 it is on the passenger side of my front bumper it had a clip that was holding the plug in on the bumper with a black capThis is not where it is located.
Is it on the sticker?I'm convinced mine is missing the block heater. I can not find the cord anywhere. I've looked high and low, inside and out of the bumper, intake area, etc. Guess I'm going back to the dealership.
Ok going to take pics of my engine block for you to check I need to replace my cable as it is damaged
on the passenger side of the truck on the 6.7 which it looks like you have but pull back the front liner ... didn't have to remove any screws but once you do the plug you see on the block is the block heater
Thanks, brotha, I'll tear into it when I get home tonight and see if I can find it. I really appreciate your help.on the passenger side of the truck on the 6.7 which it looks like you have but pull back the front liner ... didn't have to remove any screws but once you do the plug you see on the block is the block heater
the cable should lead to the front of the truck ...
i know the video is a older 6.7 but it is the same location
no problem, been doing research since mine got damaged and i need to replace it ... and they are on back order as of now ... will fine out more on the 21st JanThanks, brotha, I'll tear into it when I get home tonight and see if I can find it. I really appreciate your help.
Hell yea, glad I could help you outFound it! Those SOBs never finished the installation. Its bundled and hanging near the passenger front spring. Thanks @Chris21667 your photos helped me track it down.
