Duratracs mountain snowflake rated?
ccw
Founding Member
Washington
2022 F-350 Tremor 7.3L
1980 Mazda RX-7
I've read multiple times that the factory duratracs are snowflake rated but I can't find the symbol on the tire sidewall. Am I missing something? 285/75/18 126Q
2022 tremor fyi
There was another thread somewhere that was discussing this. Appears something changed between model years or something.
Lots of folks with tires that do have the mountain snowflake, but my truck also doesn't (22MY). IIRC from that thread, all the folks with the mountain snowflake have trucks that are 20MY and/or 21MY.
ccw
Founding Member
Washington
1980 Mazda RX-7
Here's the thread. Scroll backwards from the post I linked to:
ccw
Founding Member
Washington
1980 Mazda RX-7
I'm not in a cold weather State.
It seems to be model year dependent, so yet another example of Ford's recent cost-cutting measures.
I don’t see how it’s a cost cutting measure unless the tires also changed? My understanding is that the tire manufacturer has to pay for certification once per model.
So did the tires materially change?
Jericho
Founding Member
Texas
Veteran
2021 Lariat Tremor 7.3L
The compound is different, so the material is necessarily different.
I'm not speaking authoritatively, but any time a performance certification is removed, one can reasonably assume there is an accompanying cost reduction to Ford.
I just sold my factory take-off's and the only thing the buyer cared about was that mountain logo.
ccw
Founding Member
Washington
1980 Mazda RX-7
I'm not speaking authoritatively, but any time a performance certification is removed, one can reasonably assume there is an accompanying cost reduction.
True. Well, I just sent a message to GoodYear about it. Will update this thread when I hear back (they said to allow 48 hours for a response).
OP
E
EverythingZen
Tremor Fan
Ontario Canada
Infantry
2022 F350 tremor
So for those of use in Canada that get a discount with winter tires installed, these will no longer work even though they're the same tire. Kinda pissed as I was expecting to not buy a second set of everything for winter..... Wonder if there is any change at all to the tire itself or not.
Jericho
Founding Member
Texas
Veteran
Sincerely though... It's not the same tire any more than an E rated tire differs from an F.
I legitimately do not know Ford's reasoning, but that is why the first place my mind went was cost-cutting; same as the decreasing paint quality and QA processes, the removal of under-hood and interior lights such as the cup holders, the ever-cheapening leather, loss of articulating headrests, the violent stepped wave coming from that inverter, the plastic pan and cheap components in the transmission, and that suspension which is good enough, but not good.
I'm not assuming Ford is unique in this regard, but the company is not doing well and as a result, I'm already $14,000 into replacing subpar components on my $75,000 2021 Superduty with 1500 miles.
Backwoodsrider
Ontario
2019 Ford Expedition Max Platinum
My 2022 does not show the snowflake either. But, the Goodyear website still shows this:
Sludgemonkey44
Founding Member
TOTM Winner
Butler, Pennsylvania
2020 6.7 F250 Super Duty Tremor in Silver Spruce
2022 tremor fyi
Does this mean that your tires are more likely to offend someone as well? Perhaps they will suddenly encroach on some peoples’ “safe space.”🤔
