Did you try to do it immediately after start up or something? The electronics are slow and maybe it wasn’t ready?I’m towing right now and all of the sudden can’t put the truck in Tow Mode. Any ideas?
Works on mine in Tow HaulAre you trying to use adaptive cruise?
Same. I use adaptive cruise quite a bit while towing.Works on mine in Tow Haul
Do any of the other drive modes work?
You do you, but get a room!I’m at a gas stop now fucking Godzilla…
Probably was just a positional sensor issue of the column shift.They did not.
Its working now.
Seems I had to put it in reverse and then back into drive. Weird.
Thanks for the help!
We have this issue on our 2018 Expedition quite often. After many trips to the dealer, they think it's a rear solenoid issue.
My advice is to let your local dealer know so that you can start a history of it. It's going to cost us $400 to repair.
I know different vehicle, etc., but still get it documented.
At the gas station? Godzilla saysI posted this after idling about 5 minutes at start of the the trip. No change after warming up most of the way.
Didn’t work after restarting.
Trying again after fueling.
