Disable Auto Engine Idle Shutdown push button trucks
ndddiesels
LA
Auto Engine Idle Shutdown disable.
Confirmed working on 2021 F350 6.7L Limited Dually with push button start.
IPC Cluster AsBuilt
720-01-01
x*xx xxxx xxxx
AEIS With Override, ABS Config, ACC Menu Config, Adaptive Cruise
0=AEIS disabled, ABS disabled, ACC menu disabled, AC disabled
8=AEIS enabled, ABS disabled, ACC menu disabled, AC disabled
1=AEIS disabled, ABS disabled, ACC menu disabled, AC enabled
9=AEIS enabled, ABS disabled, ACC menu disabled, AC enabled
2=AEIS disabled, ABS disabled, ACC menu enabled, AC disabled
A=AEIS enabled, ABS disabled, ACC menu enabled, AC disabled
3=AEIS disabled, ABS disabled, ACC menu enabled, AC enabled
B=AEIS enabled, ABS disabled, ACC menu enabled, AC enabled
4=AEIS disabled, ABS enabled, ACC menu disabled, AC disabled
C=AEIS enabled, ABS enabled, ACC menu disabled, AC disabled
5=AEIS disabled, ABS enabled, ACC menu disabled, AC enabled
D=AEIS enabled, ABS enabled, ACC menu disabled, AC enabled
6=AEIS disabled, ABS enabled, ACC menu enabled, AC disabled
E=AEIS enabled, ABS enabled, ACC menu enabled, AC disabled
7=AEIS disabled, ABS enabled, ACC menu enabled, AC enabled
F=AEIS enabled, ABS enabled, ACC menu enabled, AC enabled
A more concise way to say this is, if all you want to do is disable AEIS, subtract 8 from whatever number is currently in this position. Remember that A=10, B=11, C=12, D=13, E=14, F=15.
