Deaver Progressive Leaf Packs Air Bags
Scantone
Tampa
Current Rides #1
2021 F350 Tremor
Anyone know the type (part number) for airbags when using the Deaver Progressive Leafs?
You talking about long travel bags or a custom setup with a combo of daystar cradle and firestone bags? You can also run summo springs on the bump stop drops that come with the leafs. That way you can take them off when not towing.
I'm guessing long travels the best/correct installation?
Best is subjective. Long Travels are still going limit your rear travel but are a great solution. Firestone bags with a daystar cradle won't limit travel, and the sumo springs are just a less expensive/less adjustable airbag alternative (if you're OCD and want a completely level load probably not your best choice, but you can completely remove them when not towing). Pretty sure CJC has some videos on long travel airbags somewhere.
Also, the long travel air bags (to my knowledge) are only applicable to the 4-4 1/2" lifts.
Oh yeah that's an important factor as well lol.
So looks like you would need something like the Torque TR2600 2wd Kit with the Daystar Cradles to work with the none lifted Deaver springs.
I'd have to go dig up the thread on the FTE but I'm pretty sure people are using the ride-rite 4wd kit with a daystar. Don't quote me on that yet tho.
EDIT: NOPE I was wrong, it looks like the 2WD Torque Kit and Cradle are the way to go.
Thats where I just found the 2wd info
