Ordered a '22 MY Sport F350 Lariat.
I'm coming out of an '11 Raptor Screw. I LOVED the ride both on and off road at high speeds! She seemed to have handled BETTER at high speed on dirt than on paved highway!
I want the Tremor to handle like that. I'm thinking the following:
Base Kit - Carli Pintop System: $3905
Front Sway Bar Option - Torson Sway Bar - With End Links Leveling: $1165
SKU:
CS-FTSB-LVL-17
- Direct Fitment to Carli Leveling Lifts
- Replaces Immobile Factory Sway Bar with Custom Torsion Bar
- Huge Ride Quality Improvement
- Includes CS-FEL-LVL-17 Drop Brackets and Sway Bar Links
- Fitment: 2017+ Ford F250/F350 4x4
Rear Leaf Option - Ford Full Progressive Leaf Packs: $1670
SKU:
CS-FFSP-LVL-17
- Block eliminating, Full Progressive Spring Pack
- "Light" 3/4-Ton Capacity, Max Bed-load 2,000lbs.
- Includes new U-Bolts and Rear Bump Stop Drops
- Provides a 1", rear high stance on Matching 2.5" Leveling Suspension Systems
- 37" Tire Fitment
- Fitment: 2017+ F250/350 4x4, Diesel 3.5-4.0" Axle Tube
Radius Arm Option - Ford Radius Arms: 2.5" - 3/5": $1490
SKU:
CS-FARA-LVL-05
- 1°-4° of adjustable Caster correction
- 3/16 Construction, Fully Internal Gusseted with 1/2" Additional Tire Clearance
- Limit Straps Kit Included
- Serviceable 17-4 Stainless Spherical Joint at Frame Connection for longevity and bind free Cycling
- Combines with Radius Arm Drop Brackets for 4.5"-5.5" Carli Systems
- Fitment: 2005+ F250/350 4x4
High Mount Steering Stabilizer: $370
SKU:
CS-FHMSS-17
Inside the Carli Stainless Stabilizer
- Long Lasting Performance and Appearance
- Bolt in Replacement for OEM Stabilizer
- Works on leveled and lifted trucks ONLY
Low Mount Steering Stabilizer: $660
SKU: CS-FLMSS-05
- Custom Valved for Larger Tires, Adjustable Nitrogen Pressure
- Includes Differential Guard and Clamp
- Combines with High-Mount Stabilizer for Opposing Setup
- Optimized for Carli 2.5"-5.5" Systems
Total: $9,260
I primarily went with Lariat VS King Ranch to suspension because I want this to ride more like the Raptor.
What are your guys thoughts on this? Will this setup achieve a close ride? ALSO - I'm going to upgrade to 37" tires with this setup is the hope along with airbags.
Thanx for the future input.
