Carli Track Bar alignment question
Alpoba
Founding Member
NJ
Guys with carli installs, please do me a favor and look at your carli track bar at the frame side, is it similar to how mine is or is it more centered/parallel to the frame as is shown in Carli install guide photo.
Myself and @Grabber were checking it out yesterday because my rig started making clunking noises at near full turns. He actially could hear it as i was turning into park. Could this be the reason? should the track bar be adjusted to be better centered where it is not making any metal to metal contact with the frame.
The last pro front end shop i took it too couldnt figure out the source of the clunking noise, but i think @Grabber was immediately on to something.
@Tx-Tremor6.7 @Supercup @Vecman @BLACKCHERRY
Vecman
Founding Member
Queen Creek, AZ
2022 F-350 Platinum Tremor
2021 Ranger Tremor
Just saw this. Ill check it out in the morning and see what I see
stufarmer
Founding Member
Tampa
Air Force
19' F450 KR .. 20' Lincoln Continental
The picture on the left is typical. It's a threw bolted bearing thats designed to rotate. I do suggest re-checking its torque when you're under there greasing the ft Axle Joints and Sway Bar links.
Gus
Tremor Junkie
Colorado
We noticed a clunk when turning left last night when the steering wheel is turned at least 80% as far as it goes left. It’s not the steering pump, no knock when stopped & can’t figure it out
OP
OP
Alpoba
Alpoba
Founding Member
NJ
Ditto. That is the same clunk i have been trying to diagnose for a month.
OP
OP
Alpoba
Alpoba
Founding Member
NJ
I suspected that was the case, aligned the track bar so that the uniball frame joint was parralel to the frame, a few miles later it is back to the position as pictured above.
@Gus how is yours lined up? Can you take a photo? I doubt that’s the root cause of the clunk, but i too am out of ideas.
IronChad
Tremor Buff
Yucaipa, San Bernardino CA
2022 F250 Tremor Diesel
First Responder
Law Enforcement
I have a clunk as well, but didn’t start getting the sound until I had the radius arms, torsion sway bar, and both high and low mount stabilizers installed. Just figured it was normal.
OP
OP
Alpoba
Alpoba
Founding Member
NJ
Amazing. I wonder how many of us with Carli inherited this clunk with the install. Because i too started noticing it immediately after the install, it was not there on my factory suspension. And being that i’m OCD when it comes to things like these, it is not OK with me, and i have been trying to figure it out. Took it to a pro front end shop who specializes in these type of issues. A few diagnosis labor hours later, they couldn’t pinpoint the root cause, and i’m still clunking. Obviously i can’t take it to Ford to diagnose being that it’s an aftermarket induced clunk.
I’m beginning to live up to the reality of a custom suspension and the challenges dealing with an issue. Carli will say, it was your installer, everything is designed to work together flawlessly. Ford will say its not factory, we can’t cover it. Independent shops will struggle to diagnose the issue.
IronChad
Tremor Buff
First Responder
Law Enforcement
Let me rephrase what I wrote, I originally had the Carli Pintop kit installed while the other parts came in as they were back ordered. And I had no clunk with just that. It was only when I got my truck back yesterday after having the rest of the parts installed I notice a clunk when turning left.
Gus
Tremor Junkie
Colorado
I’m anal about vehicles and never noticed it before the suspension upgrade, was going to call the 4x4 shop Monday & see what they said. Have a appointment in Oct for inspection/re torquing and figure will have 700-900 miles on it by then
Need to hit the car wash, wet muddy dirt roads = ick crusted on but have unlimited washes so will hit the tunnel wash and see how it cleans things up
Will try and get pictures
Gus
Tremor Junkie
Colorado
This is my first aftermarket suspension upgrade & spent months researching before ordering the Tremor and planning for a Carli suspension
Everyone I ever talked to said they are incredible and well worth the price and then the E Venture dropped so I threw the entire catalog onto the Tremor
So far other than the clunk have not been disappointed, only time will tell how things pan out
Gus
Tremor Junkie
Colorado
Well this narrows things down “radius arms, torsion sway bar, and both high and low mount stabilizers”
Wonder if we found a empty parking lot & the wife did slow left turns around me that would help narrow it down lol
OP
OP
Alpoba
Alpoba
Founding Member
NJ
I’m thinking it’s the torsion away bar personally
I thought about it - can’t see how the sway bar would make clunks on regular turns. I don’t see it moving much
I could see it being the stabilizers or in my case highly likely it’s the drag link.
Here’s what i can observe with suspect parts movement on mine.
stufarmer
Founding Member
Tampa
Air Force
I've never totally gotten rid of the 'clunk' after the Trac Bar installation. After re-torquing it, the sound only goes away for a day or two. I recently began thinking the sound could be from the Sway Bar links, because I cant get them to take any grease at all. Idk ..
Gus
Tremor Junkie
Colorado
Is this what you wanted?
Spoonman
Tremor Buff
SoCal
2022 F250 6.7 Lariat Ultimate Tremor Iconic Silver
2015 Big turbo Audi Wagon/ 981 Porsche Cayman - track car
Guys, its the Heim joints. That's par for the course. The ball and socket configuration creates noise when the joint has to twist enough to reach the limit of it's range of motion. This happens pretty frequently when pulling into a driveway or cranking the wheel over to full lock when backing out of a parking space etc. I have had plenty of race car suspension parts utilizing heim joints and they make noise. But the upside is they are significantly stronger and servicable.
My Audi has Heim joints on the upper control arms and they are noisy as well when I pull i to the driveway or have the wheel fully cocked while reversing.
