- Joined
- Mar 25, 2021
- Messages
- 38
- Reaction Points
- 193
- Location
- Brevard NC
- Current Ride
- 2021 F-250 Tremor XLT
- Current Ride #2
- 2018 Toyota Highlander XLE
After about 1300 miles of break-in we hooked up our Coleman lite 35' bunkhouse. Its dry weight is just over 7000 lbs, loaded Im just under 10,000. After setting it on the hitch it was almost perfectly level. I added the load leveling bars just for the bounce mitigation. I averaged just over 9MPG going up and down steep mountain grades windy roads. Tow haul did great and managed shifting and speeds well. I felt the shuttering or spark knocking people described immediately starting out. I figured I had an ignition wire or plug issue like others had described, however after a few miles and hill pulls it worked itself out. I figured since this was my first tow the engine/computer was still learning. 6-8% grades most of the way and I couldn't be happier with my purchase. LOADS of power left with the 7.3 gasser. Never thought I needed more and the truck did a great job of managing the torque and shifting! On my 2008 6.4 the sway control bar was always used, however this time i decided to go without to test the trucks built-in sway control. It handled beautifully at speeds around 65 on the straights.
