Build question
Evolrider
New Mexico
Current Rides #1
2022 Lariat Tremor 7.3 carbonized gray
I cant seem to find the answer to this question so thought I would try here. Below is my build out that was submitted. I still need them to add the rain sensing wipers w/ heated steering wheel (60W) that is not on fords website, also adding the upfitter switches. My question though is when I select the Quad-Beam option it wants to remove the bed liner, wheel well liners, tremor package and appearance package? Does that mean its not an option for the tremor or that possibly it is already included?
View attachment 23982View attachment 23983
The Lariat Black Package comes with its own special blacked out Led Quadbeams. No need to select them again. That’s where you’re running into an issue. Good luck with the build and order and feel free to ask away. Good people on here. ???
Whatever you do. Don’t order a 10000 gvwr package
I didn't select it during the build, this is how the build came from the dealer. To be honest I don't really understand if selecting or not selecting it is worse? I know it messes up the payload rating, should I have them remove that line from the build?
The Lariat Black Package comes with its own special blacked out Led Quadbeams. No need to select them again. That’s where you’re running into an issue. Good luck with the build and order and feel free to ask away. Good people one here. ???
That makes perfect sense now, my current F150 has the black package with those lights!
Awesome. And I believe you’re observed loss of the Tremor package is actually just a loss of the discount associated with the combination of the Tremor and blackout packages if you click on that little info button beside that line. I could be wrong though. ???
I’m a bit surprised it’s showing up on the order, but regardless 10,000 GVWR is the highest available for the F-250 gas Tremor (see page 13 of the towing guide) so you’re good to go.
That package is a concern for any other configuration (350 and/or diesel) as it will derate it.
It's part of a package and by selecting it as an individual add on the system wants to delete the package that pertains.
Wow thanks for the info. I almost had a heart attack. My 250 is ordered the same way. And I definitely want those LED lights.
