Brake pedal height
Vicious-Peanut
Tremor Buff
TX
Is it just me?! I have the power pedal but it keeps the gas and brake tied together and the brake feels wayyyy too far forward. Anything I’m missing or I just need to get used to it?
When I first got in to drive it , it thought the same thing. It seems way to far out for my taste. Anyway to adjust it?
Do you guys mean too close to the driver or too far away from the driver?
For me the brake is too close to me. The gas and brake seem farther apart (distance from driver) than most cars
I agree. Not sure why the brake pedal is so much closer to the driver. Reminds me of my '96 F150.
I actually like the pedal layout - feels exactly my my 2001 F250 that I racked up a ton on miles one. It's about the only thing that feels familiar between the two trucks. I do have the movable pedals and adjusted it to my liking though....
Ed
Ed
Yeah mine does too but it’s the difference in the gas / brake that throw me off
Are both pedals independently adjustable or is it just the gas pedal with the brake moving along with it?
Reviving an old thread here since I had this issue and it took me weeks of searching to find the solution...
This applies to ford power adjustable pedals only. This will result in reduced adjustment depending on how far you adjust the single pedal.
The pedals are adjusted by square-drive cables driven by a motor up in the dash. Extend the pedals to the bottom position of their travel. On the brake pedal, reach up above the pedal and find where the cable (about 3/8" diameter) meets the adjustment screw. Simply undo the twist lock and pull the cable out of the adjustment screw assembly and place out of the way. At this point, you have (mechanically) disabled the power adjustment for the brake pedal.
Next, use the power adjust toggle to move the accelerator pedal to the desired position. For me, this was about half of the available travel.
Finally, reconnect the square-drive cable to the adjuster screw assembly and twist lock back into place.
I was able to put my pedals in a much more comfortable position while still retaining about half of the adjustment of both pedals using the toggle.
To undo, simply follow process in reverse.
Hopefully this helps some of you out there!
Very clear and makes total sense. Thanks for sharing this!!
Bumping this thread, as I plan to do this tonight.
Did this on my 2020 without any issues, trying to do it now on my new 2024....cant get that cable out at all. Undid the twist lock but cable won't budge. About to use some pliers but before I tear up a brand new truck, anyone have the same issue?
Going to try this. Never seen this thread before but hate the staggered setup of the pedals. Hope it’s as easy as it looks.
Wait a minute, so you independently adjusted the brake and gas pedal to make them more inline (closer to equidistance) from the driver? Then hooked the power pedals back up so now they move in unison again for minor adjustments? That's pretty cool
Just tried it on my ‘22 this morning. Undid the twist lock but the cable won’t budge…might try some pliers later
Glad it wasn't just me....let me know if that works, I won't be able to get to try mine until the weekend.
