Bluetooth Phone Calls suck?
bbrett
Founding Member
TOTM Winner
Camarillo, CA and Corona, CA
2020 Ford F250 Lariat Tremor
I get complaints all the time from people that they can't hear me and it sounds like im standing 10ft away from my phone. my friend has a F250 also and he said he gets the same complaint. My ram was crystal clear, it annoying having to repeat myself. anyone else having the same issue? I know its not my phone, anyone else have similar complaints?
davidb1841
Founding Member
Sand Hills of NC
USAF Ret
2020 Ford F250 Tremor Velocity Blue
2019 Ford Edge SEL
Mine works great...crystal clear with my new 5g phone
boukaal
Founding Member
Texas
2020 F250 Lariat Sport Tremor
Bluetooth or CarPlay? I’ve had the same, seems like something is up with CarPlay. If I unplug and plug back in they can magically hear me, as if it was using the phone mic instead of the truck until I reset it. I’ve been having other weird CarPlay issues - sometimes just a black screen, sometimes no CarPlay until I unplug and plug back in. not sure if my phone or the truck but a big pain.
IceSoldier88
Founding Member
North Central NY
Army
Velocity Blue F350 Diesel with Sport & Ultimate package
20 Explorer / 18 Indian Chieftain Limited / 19 Can-Am Defender XMR
First Responder
Volunteer Firefighter
Iv had car play issues also. sometimes when i connect my phone and then try and adjust the radio it is stuck in prompt volume adjustment.
davidb1841
Founding Member
Sand Hills of NC
USAF Ret
2019 Ford Edge SEL
Im just using bluetooth
Driftwood
First Tremor on Methods!
Staff member
Driftwood, TX
2020 F250 Tremor 7.3L Lariat w/ Ultimate & Sport
I've had some people say it sounds like there's an echo when I am using Bluetooth on my Note 10. Other times it seems fine. Maybe it's a signal strength or coverage issue in my case.
PapaRaptor
Founding Member
USA
6.7 F350 Tremor "Velocity" Blue Lariat Sport
7.3 "Godzilla" F350 Dually "Iconic silver" 4x4
Think the Tremor is bad, try the blue tooth phone in an FCA product.
boukaal
Founding Member
Texas
I've had the same and it is getting more regular. The other day had to turn the truck off and on to fix it. I guess it's not my phone...
MTBKNG
Tremor Buff
Nor Cal
Yes to your first question, I get that a lot actually, but then I move my phone out of the center console cup holders and put it on the top arm center rest and within about 30 seconds they can hear me much better.
Cybermig
Founding Member
Asheville, NC
2020 F250 Tremor XLT
There's a known issue that matches what you describe and it affects many of us on this forum. Essentially the issue is related to having Waze on your phone and attaching to the truck via Apple Carplay. That issue in particular is a result of Waze taking over your microphone on your phone so you can do voice requests, but when you get a call and you answer it, Waze doesn't release your microphone and essentially you get a poor microphone experience for the people on the other end of the phone which sounds exactly as the OP described above. There's supposed to be an update coming from Waze about this. Also, a Sync update did also come out not that long ago which was mentioned earlier.
If the issue is purely from Bluetooth and not CarPlay, it may be vehicle microphone related. You could also try unpairing and re-pairing your phone. Seems there's numerous gremlins at play with these infotainment systems.
PapaRaptor
Founding Member
USA
My 2019 Ram Limited was Crystal Clear and no one ever knew I was actually talking in my truck. the 12.1" UConnect system is another story. POS
Ram is probably better than Jeep Wrangler
richtor
Tremor Addict
Sonoma County
Race Red F250 Tremor
Is the 12.1 Uconnect not in the Ram? My uconnect in my 12 JK Rubi was good, just had too much road noise in the jeep. Haha
Groot
Tremor Buff
EL Paso Texas
U.S. Army ret.
2020 F250 Tremor
2007 Harley Davidson FXDB
mine is clear as day no issues
