BDS Fox 2.5 inch Coil Over Suspension
SVT4X4
Michigan
2020 F250 Tremor
Finally was able to get out and test the BDS 2.5 inch coil over suspension system and can't be any happier. This with the dual shocks kept me from bottoming out (most of the time) in the sand dunes, compared to my Dad's 2 inch coil spacer lift truck with stock shocks that kept bottom out. This is certainly not a Raptor suspension, but I was able to run over some pretty good whoops at high speed and it handled great. This kit included the 2.5 inch Fox coil overs, 2 inch Fox shocks front and back, heavy duty track bar, radius arms, 1 inch block in rear and all hardware. Then I upgraded with a dual steering stabilizer system to hopefully prevent that death wobble.
Finally was able to get out and test the BDS 2.5 inch coil over suspension system and can't be any happier. This with the dual shocks kept me from bottoming out (most of the time) in the sand dunes, compared to my Dad's 2 inch coil spacer lift truck with stock shocks that kept bottom out. This is certainly not a Raptor suspension, but I was able to run over some pretty good whoops at high speed and it handled great. This kit included the 2.5 inch Fox coil overs, 2 inch Fox shocks front and back, heavy duty track bar, radius arms, 1 inch block in rear and all hardware. Then I upgraded with a dual steering stabilizer system to hopefully prevent that death wobble. View attachment 6907View attachment 6908View attachment 6909View attachment 6910
Sweet Set Up. What did it cost you.
Looking at around $4000 depending where you purchase. I was able to get it installed at no charge from BDS in Michigan because they were looking for a Tremor to do, and had not done one yet.
Sweet deal. I’ve seen videos on Carli 2.5 Pintop Suspension with Fox Shocks. Snake Pit has a sweet set up as well. He’s also got the Velocity Blue.
I love your set up. Best of luck with it. I’m still waiting for my order of a 2021 F-350 Tremor to be pulled. As I see your sweet set up I’m feeling more frustrated to get my so I can have a FAT ASS SET UP LIKE YOURS ???✌️?????????
