Baja Designs reverse lights
Whyte Rhyno
Tremor Addict
Montana
2020 F250 Lariat 6.7 Powerstroke
1974 F250 Highboy
Finally got around to installing the reverse light kit from Baja designs. Wiring is great. Lights look bulletproof. Bracket is kinda eh. Doesn’t have enough clearance for the wiring as it exists the light housing. But it gets the job done. Plenty of wiring length. Too much actually. Had a sizable bundle to wrap up and tie off. Tucked it up on top of the spare tire mount. Can’t wait to see what they look like at night.
I’m getting close to ordering a set. Given the bracket, would you order again or just get creative with another option?
I’d get it again. Bracket just looks like an afterthought given how nice the wiring is and how solid the light is built. It’s definitely a cool set up. Tucked up nicely. The bracket has some adjustability to it so you can fine tune the fit.
Could the S2 flush mounts not be cut into the OEM rear bumper? That would be a lot cleaner, nicer look.
It was Rigid lights, but at least one person on the forum has installed flush mount lights into their bumper: https://www.fordtremor.com/threads/rigid-lights-rear-bumper.2317/
Look great! Just requires the commitment to cut into your bumper. ;)
I would imagine the S2’s would work great as well for that.
We've got the Baja Designs Reverse kits in stock that go to your upfitters. Can also do a custom setup from Rigid or Baja Designs with plug and play wiring kits and even dual function kits to kick on automatically with reverse lights and/or be operated by your upfitter or other in-cab switch. If anyone is interested, please feel free to reach out.
Yes, that is what I did for my Amber chase lights on the back of my truck. The work great and the installation in the bumper makes it look very clean without needing the brackets. I chose Amber to make them work for chase lights, as well as lighting up the area behind my truck for backing up and hooking up my camper at night. I had the smaller BD lights with the brackets at the bottom of my hitch on my Raptor, so I wanted to try something different on the Tremor.
Mine are wired to one of my upfitter switches with the plug and play harness Nick mentioned above.
Very clean install, looks sharp and great chase lights!
Ranch Hand Summit, not winch compatible with 30” s8 Baja design. Soon to flush mount s1in ranch hand Pro style rear bumper. Baja Design makes quality products! ?
That looks amazing! I did something similar on my F-150 and am thinking about doing this for my F-350 now. I had clear lights and didn't think about adding yellow. Do you have a night shot of these lights on? Would love to see the output
I have Baja Design S-2's in rear bumper - they are smaller, but the Squadron sports throw more light - both can be had in clear or amber.
Baja makes some great lights! The S2 is a great option and as others have mentioned, comes in both a flush mount and surface mount. The other light to consider is the S1. Slightly smaller and square housing and they're incredibly bright.
S2 Sport = 1,581 lumens per light ($225.95/pair retail price for surface mount)
S2 Pro (pair) = 2,450 lumens per light ($339.95/pair retail price for surface mount)
S1 (pair) = 2,320 lumens per light ($225.95/pair retail price for surface mount)
We carry a TON of Baja Designs lights in stock. Shoot us a PM, email us or check us out online.
Interwebs --->>> OFFROADALLIANCE.COM
S2 flush mount:
S1 flush mount:
