Any body else seeing bad axle wrap with the 7.3, 4.30 gears and stock suspension. Seems like if I'm barely on the throttle in loose, thick sand the rear end will start hopping bad (forward or reverse) with traction control on or off. If I stomp it it powers past it but with low to medium throttle it can be bad. My old '05 with the 5.4 and 3.73 gears did it with stock tires but when I changed to 35's it stopped.
