- Joined
- Jun 1, 2021
- Messages
- 404
- Reaction Points
- 2,077
- Location
- Southern CA
- Current Ride
- 2022 F250, Tremor
- Current Ride #2
- 2003 Ram 2500 HO
I try to adjust the volume in this truck and the latency is TERRIBLE. It will literally process a change for seconds before doing anything. Sometimes it makes the change, others it ignores, others it does half. I find myself over and under-correcting volume all the time as a result. Does the same thing when i adjust on the steering wheel.
Some other things that irritate me... the incoming call volume not being separate from the media volume... If i have the sounds low and a call comes in, it will ring it at the super-low volume then the volume knob latency takes a solid few seconds trying to dial in the callers voice-level to a workable volume.
I added a bunch of aftermarket goodies to the stereo but the issue seems to be with the factory head-unit/interface, not a result the ZEN module; that should be down-stream, right?
Anyone else have this issue? My electronic adjusting column tilt doesn't function so it needs to go to the dealer anyway but thought i'd see if this was common.
