AIr compressor
Flourman
Tremor Fanatic
Colorado
2022 F350 Lariat Tremor
2019 Beta 300RR
ARB twin here. Something I didn’t expect, the air outlet gets hot AF, which is normal for these but pay attention to the hoses you put on or hardline to a tank.
Flourman
Tremor Fanatic
Colorado
2019 Beta 300RR
I’ve never see. A setup in the engine bay. Will that Fit a F-250 or F-350 Diesel?
It’s in a F350 gasser with a single battery so lots of room in the engine bay. I “upcycled” a bracket from a Jeep side step bracket.
PapaRaptor
Tremor Maniac
USA
6.7 F350 Tremor "Velocity" Blue Lariat Sport
7.3 F350 Iconic silver THE SILVER FOX
ARB twin on the Tremor. Add an air tank! Many threads on this.
I have the single on my Jeep its ok but with a larger electrical system the twin would be great. The single will air up my 35 x 12.50s no problem without a tank.
I have a VIAIR on another vehicle it is noisy and runs very hot I would not recommend that brand
OldCowboy
Tremor Fanatic
NC
What's the advantage of running it under the hood? If you are using upfitter switches, can't it be down on the frame?
Mattlikesbikes
Tremor Fanatic
Austin TX
2013 Tundra
2022 Lariat 6.7 - SOON
I'm planning on the VIAIR Medium Duty. https://www.amazon.com/VIAIR-Medium-Duty-Onboard-System/dp/B000X9RX3A
Mount the tank on the frame, under the pass side (lots of forum posts on how). Compressor in the bed of the truck (probably on the pass side, front of the wheel well). Will be used for air horn, bike tire fills, and truck tire pressure ups. I don't plan to do heavy offroading or much with dropping the pressure too low, so don't need the run time to put 20+ PSI in every tire quickly.
knaffie
Tremor Buff
Zephyr Cove, NV
2022 F350
FYI, ARB recommends never mounting their compressors under the hood. It gets too hot and will cause premature failure. They told me their compressors are completely waterproof so it is safe to mount them on the frame, under the body, above the spare tire, etc. Anywhere but under the hood where it's hot.
Pompey
Tremoraholic
Granite Belt, Queensland
Ranger PX2 3.2TD
1999 Subaru WRX Club Spec Evo 3
From the ARB website
knaffie
Tremor Buff
Zephyr Cove, NV
2022 F350
Despite what this document says "under bonnets" I've talked to two different people at ARB, about a year apart when dealing with a failed compressor for a friend, and both of them said they have a significantly higher rate of failure from mounting these under the hood. The one guy said they were actually having an internal meeting about what to do about all of the aftermarket manufacturers making mounting brackets to put these under the hood of Jeeps because of the high rate of failure it was causing. He literally said mount it anywhere I want except under the hood. Mine ended up under the passenger seat of my Jeep.
Pompey
Tremoraholic
Ranger PX2 3.2TD
It makes sense what you say. Sounds like a case of the left hand not knowing what the right hand is doing
knaffie
Tremor Buff
Zephyr Cove, NV
2022 F350
Would an ARB twin supply enough air to use a blow nozzle without a tank?
Not really. You need a small tank. Even with a small tank, you only get a couple second burst of high pressure, then it has to recharge for a few seconds before you get high pressure again. I have the ARB portable twin (that includes a small tank) I keep in my trailer and the ARB twin in my Jeep (no tank). You can use a blow nozzle with them for quick fixes, but it's not ideal.
Flourman
Tremor Fanatic
Colorado
2019 Beta 300RR
Because I wanted to…. 😂
In reality, it’s because it was easiest in terms of what I wanted to do. The power harness was a perfect fit to run across the top of the firewall without having to run more wire. Also the ease of access to the upfitter switch wires. The ONLY things I really plan to use it for are airing up tires and then to blow out my camper water lines during late/early season camping. When running, the hood will be up and the air intake will be right at the top of the hood line. I’m not using it to run air tools or air lockers so a tank is not needed.
And, in reality, I’ve seen most mounted under the hood in Jeep applications so that’s where I put it. I didn’t even think about mounting under the frame and I didn’t want it in the bed. I live in a salt area and also deal with a lot of gravel roads. Even though they are waterproof, I didn’t want it exposed to those.
I may move it later but it works for now.
If you aren’t using air tools or a horn, there is really no need for a tank. The compressor has to run just as much to fill a tire regardless if there is a tank. It may not run it at the same time.
News to me. I guess the bazillion that I’ve seen mounted under hoods were wrong.
Vermonster
Dude - Where's my truck?
Vermont
2011 BMW E90 335i XDrive (modded to be faster and stronger)
1974, BMW 2002 (building project), 2021 Subaru Ascent (Wife's car), 2015 Ducati 899 & 2000 Ducati 748 Mono
My Hummer had onboard air. It was pretty handy with beach toys. I never really needed to air down / or back-up on my own. However, it did also power the rear air bags for the suspension.
It's funny how I never really had a desire to add a on-board compressor, but then having seen this (and other threads) I feel like I want/need one. The power of the Internet!
Edited for TYPOS - marked in bold! :rolleyes:
