Note: This feature currently requires accessing the site using the built-in Safari browser.
So the handle to disengage the turnover ball is still completely accessible and not blocked in any way? Thanks! TimI didn't run into any problems...Running BW and Airlift airbags & wireless controller (94352 & 25980EZ)
OK. It sounds like the Firestone brand airbag brackets could interfere with the handle in some fashion but the AirLift brand will not is what I am finding out. So be aware. Thanks Again.The handle is behind the wheel well liner but no real interference at all. In the photo below the handle is all the way out. Works great.
What does the frame-mounted handle do for the BW hitch?The handle is behind the wheel well liner but no real interference at all. In the photo below the handle is all the way out. Works great.
This is the BW Turnover Ball. When you pull the handle out it releases a pin so that you can turn the gooseneck ball upside down and makes your bed totally flat. Basically just a way to store your gooseneck ball out of the way.What does the frame-mounted handle do for the BW hitch?
