7.3 Engine Info
SVT4X4
Michigan
Current Rides #1
2020 F250 Tremor
Specifications
Materials
NameSpecification
Engine Oil - SAE 5W-30 - Synthetic Blend Motor Oil
XO-5W30-Q1SP
WSS-M2C946-B1
Engine
Item​
Specification​
Bore4.2205 in (107.2 mm)
Stroke3.9764 in (101 mm)
Displacement
7.3L (445 CID)​
No. of cylinders
8​
Compression ratio
10.5:1​
Engine weight (without accessory drive components and with flexplate)580 lb (263 kg)
Firing order
1-5-4-8-6-3-7-2​
Spark plug12405
Engine Oil
ItemSpecification
Material : Engine Oil - SAE 5W-30 - Synthetic Blend Motor Oil / XO-5W30-Q1SP (WSS-M2C946-B1)​
WSS-M2C946-B1
Engine Oil Capacity
ItemSpecification
Service fill including oil filter​
8 qt (7.5 L)
Torque Specifications
Engine oil drain plug: 19 lb.ft (26 Nm)
Oil Pressure
ItemSpecification
Minimum oil pressure at idle (engine at normal operating temperature)​
8.0 psi (55 kPa)
Cylinder Head
ItemSpecification
Head gasket surface flatness​
0.025 mm (0.001 in) in any 25 mm (1 in) x 25 mm (1 in) area; 0.05 mm (0.002 in) in any 150 mm (6 in) x 150 mm (6 in) area; 0.1 mm (0.004 in) overall
Combustion chamber volume​
3.8718 in³ (63.447 cm³)
Rocker arm ratio​
1.8:1
Valve arrangement (front to rear) — LH​
I-E-I-E-I-E-I-E
Valve arrangement (front to rear) — RH​
E-I-E-I-E-I-E-I
Valve face runout — intake​
0.002 in (.05 mm)
Valve face runout — exhaust​
0.002 in (.05 mm)
Valve face angle — intake​
45.5–46°
Valve face angle — exhaust​
50.5–51°
Valve guide bore diameter​
0.314–0.315 in (7.975–8.005 mm)
Valve head diameter — intake​
2.160–2.170 in (54.87–55.13 mm)
Valve head diameter — exhaust​
1.664–1.674 in (42.27–42.53 mm)
Valve seat width — intake​
0.067–0.079 in (1.7–2 mm)
Valve seat width — exhaust​
0.051–0.063 in (1.3–1.6 mm)
Valve seat angle — intake​
44.5–45.5°
Valve seat angle — exhaust​
49.5–50.5°
Valve
ItemSpecification
Valve stem diameter — intake​
0.3123–0.3131 in (7.933–7.953 mm)
Valve stem diameter — exhaust​
0.3119–0.3126 in (7.921–7.941 mm)
Valve stem-to-guide clearance — intake​
0.0009–0.0028 in (.022–.072 mm)
Valve stem-to-guide clearance — exhaust​
0.0013–0.0033 in (.034–.084 mm)
Valve Springs — Engine Code: LC3E-6007-KA
ItemSpecification
Valve spring free length — intake​
2.6197 in (66.54 mm)
Valve spring free length — exhaust​
2.7610 in (70.13 mm)
Valve spring installed height​
2.3622 in (60 mm)
Valve spring installed pressure — intake​
63.62–70.37 lb (283–313 N)
Valve spring installed pressure — exhaust​
84.75–93.75 lb (377–417 N)
Valve spring compression pressure — intake​
252.46–276.29 lb (1,123–1,229 N)
Valve spring compression pressure — exhaust​
248.86–272.24 lb (1,107–1,211 N)
Valve Springs — Engine Code: LC3E-6007-JA
ItemSpecification
2.6791 in (68.05 mm)
2.8209 in (71.65 mm)
2.3622 in (60 mm)
78.46–86.55 lb (349–385 N)
98.02–107.01 lb (436–476 N)
274.27–299.90 lb (1,220–1,334 N)
265.72–289.10 lb (1,182–1,286 N)
Camshaft
ItemSpecification
Camshaft journal bore inside diameter​
2.3617–2.3627 in (59.986–60.013 mm)
Camshaft journal-to- bearing clearance​
0.0010–0.0030 in (.025–.076 mm)
End play​
0.0030–0.0065 in (.075–.165 mm)
Journal diameter​
2.3597–2.3607 in (59.937–59.963 mm)
Lobe lift — intake​
0.2990 in (7.595 mm)
Lobe lift — exhaust​
0.3337 in (8.477 mm)
Runout​
0.0010 in (.025 mm)
Theoretical valve lift @ 0 lash — intake​
0.5433 in (13.8 mm)
Theoretical valve lift @ 0 lash — exhaust​
0.6063 in (15.4 mm)
Cylinder Block
ItemSpecification
Camshaft Bore Diameter — Journal 1 and 5​
2.5428–2.5438 in (64.588–64.613 mm)
Camshaft Bore Diameter — Journal 2 and 4​
2.5231–2.5241 in (64.088–64.113 mm)
Camshaft Bore Diameter — Journal 3​
2.5035–2.5044 in (63.588–63.613 mm)
Cylinder bore diameter​
4.2205–4.2212 in (107.2–107.218 mm)
Cylinder bore maximum taper​
0.0006 in (.016 mm)
Cylinder bore maximum out-of-round​
0.0008 in (.02 mm)
Main bearing bore inside diameter​
2.8504–2.8513 in (72.4–72.424 mm)
0.025 mm (0.0009) in any 25 mm (0.984 in) x 25 mm (0.984 in) area; 0.05 mm (0.002 in) in any 150 mm (6 in) x 150 mm (6 in) area; 0.100 mm (0.004 in) overall
Crankshaft
ItemSpecification
Connecting rod journal diameter​
2.0859–2.0867 in (52.983–53.003 mm)
Connecting rod journal maximum taper​
0.0002 in (.004 mm)
Connecting rod journal maximum out-of-round​
0.0002 in (.006 mm)
Crankshaft end play​
0.0079–0.0157 in (.2–.4 mm)
Main bearing journal diameter​
2.6568–2.6576 in (67.483–67.503 mm)
Main bearing journal maximum out-of-round​
0.0002 in (.006 mm)
Main bearing journal maximum taper​
0.0002 in (.004 mm)
Main bearing journal-to-crankshaft clearance​
0.0015–0.0025 in (.037–.064 mm)
Piston
ItemSpecification
Piston diameter (at right angle to pin bore)​
4.2181–4.2187 in (107.141–107.155 mm)
Piston-to–cylinder bore clearance (at grade size)​
0.0018–0.0030 in (.045–.077 mm)
Piston pin bore diameter​
0.9844–0.9846 in (25.005–25.01 mm)
Rings
ItemSpecification
Piston ring end gap — top​
0.0157–0.0197 in (.4–.5 mm)
Piston ring end gap — intermediate​
0.0315–0.0394 in (.8–1 mm)
Piston ring end gap — oil control​
0.0059–0.0177 in (.15–.45 mm)
Piston ring groove width — top​
0.0602–0.0610 in (1.53–1.55 mm)
Piston ring groove width — intermediate​
0.0484–0.0492 in (1.23–1.25 mm)
Piston ring groove width — oil control​
0.0996–0.1004 in (2.53–2.55 mm)
Piston ring width — top​
0.0579–0.0591 in (1.47–1.5 mm)
Piston ring width — intermediate​
0.0461–0.0472 in (1.17–1.2 mm)
Piston ring width — oil control​
0.0984 in (2.5 mm)
Piston ring-to-groove clearance — top​
0.0012–0.0031 in (.03–.08 mm)
Piston ring-to-groove clearance — intermediate​
Piston Pin
ItemSpecification
Piston pin diameter​
0.9841–0.9843 in (24.997–25 mm)
Piston pin length​
2.3563–2.3681 in (59.85–60.15 mm)
Piston pin-to-piston clearance​
0.0002–0.0005 in (.005–.013 mm)
Connecting Rod
ItemSpecification
Connecting rod bearing-to-crankshaft clearance​
0.0013–0.0034 in (.033–.086 mm)
Connecting rod length (center-to-center)​
6.3189 in (160.5 mm)
Connecting rod maximum allowed bend​
0.0008 in (.02 mm)
Connecting rod-to-pin clearance​
0.0001–0.0007 in (.003–.018 mm)
Connecting rod pin bore diameter​
0.9844–0.9848 in (25.003–25.015 mm)
Connecting rod side clearance​
0.0049–0.0187 in (.125–.475 mm)
SVT4x4 great info! Do you buy chance have a parts breakout with part numbers for the engine? I'm going to build a 7.3 for the mustang and have been looking for part numbers so I can confidently order things from the dealer.
That I don't have.
Just got through crawling underneath my Tremor 7.3l and now I have a question concerning the oil pan...Is it made of plastic? I also noticed what looks to be a cooler...I dunno but I guess I thought with an off road-y truck you'd likely not want things like that underneath.
