Billy Bob
Tremor Buff
Had a S&B 60 gallon tank installed in 2020 sometime. A few months ago I started getting a noise when I turned hard right. Worse when braking and going into gas stations. Took to 2 different shops. 1 could not replicate? Test drive with the other. Heard it but could not find the source. Thought bearings. U joint. Did not make sense. Definitely speed related with steering. I crawl underneath in parking lot and saw the driveshaft was close to the tank. Especially around the weights. Could not get my pinky in there. Called S&B. Said to send pics of bed and fill tube and everything. Called back to see if they got them. Talked to somebody else. Almost immediately said he was sending a bracket to prevent the tank from shifting. So I’m thinking I am not the first. The noise was the weight slapping the tank.
Will follow up later.
