It's all over the controls arms, crossmembers, rear axle, and even a mist on the tailgate. This is not the way I want to start out my relationship with this truck! Has anybody else had a similar problem?
If that’s from up above the transmission, there is a chance it’s from the power steering system. I’d take it in and make the dealer chase the leak.
Not really. They have a light clear fluid from the factory. You can use transmission fluid in a pinch, but I wouldn't use it unless I was stranded in the boonies and had to get home, and then I'd replace it with OEM fluid once I was able.The power steering system uses automatically transmission fluid.
-SR-
It’s the same fluid. It’s nice because you only have to stock one fluid but annoying when you need to trace a leak. Ask me how I knowIs the power steering fluid red? It's 20 degrees and my truck is covered in snow at the moment, so I'm not going to walk out and look. All the power steering fluid I've used in the past is clear, I assumed the transmission fluid was the only red fluid in the truck. I have an appointment at the dealer next week. I'm definitely not chasing around problems on a brand new truck with warranty.
The manual says that the power steering system uses MERCON LV ATF, which is the same AFT that the 6-speed transmission uses. If you have the 10-speed (which all Tremors do), you use MERCON ULV ATF for that transmission (but still LV for the power steering system).Not really. They have a light clear fluid from the factory. You can use transmission fluid in a pinch, but I wouldn't use it unless I was stranded in the boonies and had to get home, and then I'd replace it with OEM fluid once I was able.
Just dropped my truck off this AM, less than 100 miles and transmission fluid was dripping away in the driveway.
Is this a diesel or a 7.3 truck?
+1 to this. Screenshots from the 22MY manual for the transmission, transfer case, and power steering.The manual says that the power steering system uses MERCON LV ATF, which is the same AFT that the 6-speed transmission uses. If you have the 10-speed (which all Tremors do), you use MERCON ULV ATF for that transmission (but still LV for the power steering system).
IDK why they'd use something different from the factory, but anything's possible, I guess.
-SR-
Dang I did not even notice! Right on, but yeah.. tranny fluid, wtf.I live in Zephyr Cove, but got my
Diesel
Update, my front transmission pump is leaking. Ford is taking my truck back for a few weeksDang I did not even notice! Right on, but yeah.. tranny fluid, wtf.
Few weeks? Wow. I guess they dont have the parts to replace right away. You had it it for what, a few days now? I remember seeing photo of your truck in a dealers lot with a dealership sticker, sparked a discussion. That was late last week, brand new.Update, my front transmission pump is leaking. Ford is taking my truck back for a few weeks![]()
Is Ford Company actually taking it?Update, my front transmission pump is leaking. Ford is taking my truck back for a few weeks![]()
I had it for 3 days! And yeah they have to order the parts in... no loner vehicles for me to use. Bummer deal... elk hunt starts Friday..Few weeks? Wow. I guess they dont have the parts to replace right away. You had it it for what, a few days now? I remember seeing photo of your truck in a dealers lot with a dealership sticker, sparked a discussion. That was late last week, brand new.
