3D Printed Gas Cap Holder
maxspongebob
VA
2021 F250 Tremor
FoMoCo could have done a much better job on designing a gas cap tether. It is forever getting in the way when you are trying to install and tighten the gas cap.
I removed the tether completely and made this holder. The holder is stuck to the inside of the gas filler door and you store your cap on it while filling your tank. You can't close the door without removing the cap so it reminds you to reinstall your cap. Also the holder fits neatly inside the cap area with the door closed.
If you want to download and print this model you can get it from my GrabCad site. https://grabcad.com/library/ford-truck-gas-cap-holder-1
ccw
Founding Member
Washington
2009 F-150 XLT
1980 Mazda RX-7
Great idea. Every time I fill up this aggravates me to no end. You should sell those, I’d buy one.
@kmtweb was selling them at one point (pretty sure their own design, but same idea), presumably still is?
ibeb
Spokane WA
2020 F350 CCSB Lariat Tremor
I have one of these and finally got around to installing it a couple of weeks ago. Used adhesive promoter on door and holder, 3M circle adhesive and let it sit for a few days before I used it. Works great and cut that damn tether cord off!
Raspy
Founding Member
Northern Nevada
2021 F250 Tremor 7.3 Lariat
2020 Black Series HQ19
I clipped my tether off soon after getting the truck.
The cap sits on top of the bed rail while filling. It would fall off if I drove away, but I'll probably never forget to close the fuel door, which will remind me to put the cap on. If someone drove away with the cap sitting on that printed holder, it looks like it would fall off of that too.
Wayfaring Stranger
Tremor Buff
Puget Island, Washington
Ford Edge Sport
First Responder
retired police and corrections officer
It's no longer the 1970's. There are simple solutions to these problems. Our 2015 Ford Edge Sport does not have a gas cap. It doesn't need one. The door to the gas line has a built in plug on it. When you close the door, it seals the gas line. It's something all vehicles should have had 40 years ago.
ATV22Tremor
Founding Member
Texas
USAF
2022 Ford F-250 Lariat Tremor
2016 Subaru Crosstrek
He absolutely is, I just ordered one! I highly recommend him for anyone who doesn’t have the means to 3D print their own. Great quality and easy to work with! Plus he’s a fellow member!
*this is the message of a real customer. He was not paid for this advertisement!
Forever & Ever Woods
FordTremor.com Vendor
Minnesota
Army Veteran
2011 Ford Raptor (Total Loss)
1998 Chevy Silverado Z71 - 45k miles
He's out there to help. I have a 3D printer and he provides his files for free! I've downloaded them.
For those without the means to print - this is a huge help that he will provide for you!
Raspy
Founding Member
Northern Nevada
I'd like to see a picture of that. If it is anything like the Ram "capless" filler, it's terrible because the gasket does not seal dust out of the cap enclosure, or water, and those get into the filler neck. Imagine a diesel engine, with very strict fuel cleanliness specs, allowing dirt and water into the fuel filler pipe. A screw on gasketed cap is by far the best way to keep the fuel clean and in the tank. Also, the capless designs have to have a check valve in the pipe, which makes it a lot harder to fill from a gas can, or to add fuel additives. Give me an old fashioned screw on cap. Exactly what the Tremor has.
ccw
Founding Member
Washington
2009 F-150 XLT
1980 Mazda RX-7
Oh good point! Means I don't have to keep that little funnel in the truck like I do with my F-150 right now. Which is just something that can be lost.
OP
maxspongebob
maxspongebob
VA
2021 F250 Tremor
My 2013 F150 had no gas cap either. The sealing mechanism was in the gas inlet. When you shoved the pump nozzle in the hole it opened and when you took it out it closed. I don't know why they changed it back to a cap.
