- Oct 21, 2020
- 11
- 26
- 00 Trans am , 03 SVT cobra , 91 fox body, and 2021 ford F250 tremor
Just did minor trimming, Does not rub at all , even at the radius arms
I like em , there loud but that doesn’t bother me, I had 3 sets on my old Silverado I had almost 50k on em when I took em off, and the last set I had 30k on them when I traded the truck inHow you liking the federals? Thinking of putting them on my truck.
37s, no lift, no level, no trim, no rub! Just installed Method NV305HD custom painted Agate Black with Toyo Open Country A/T in 37x12.5x18. Was planning to trim and level but zero rubbing so may not. Speedometer is off 3 mph at 65 (really running 68) based on Garmin GPS. 2021 F350 Lariat with 6.7View attachment 12744View attachment 12745View attachment 12746View attachment 12747
Whats the offset on the wheel?37s, no lift, no level, no trim, no rub! Just installed Method NV305HD custom painted Agate Black with Toyo Open Country A/T in 37x12.5x18. Was planning to trim and level but zero rubbing so may not. Speedometer is off 3 mph at 65 (really running 68) based on Garmin GPS. 2021 F350 Lariat with 6.7
18Whats the offset on the wheel?
Looks great! I just leveled my 21’ with a ReadLift. Is the rear (“5”) a 5mm offset to bring flush like front (given rear is depressed per factory spec)?View attachment 12744View attachment 12745View attachment 12746View attachment 12747
Still digging the 37’s with no other suspension mods? I am debating doing the same thing….37s, no lift, no level, no trim, no rub! Just installed Method NV305HD custom painted Agate Black with Toyo Open Country A/T in 37x12.5x18. Was planning to trim and level but zero rubbing so may not. Speedometer is off 3 mph at 65 (really running 68) based on Garmin GPS. 2021 F350 Lariat with 6.7
I am curious if you are losing any suspension travel? Adding 2in of extra tire would in in theory almost bottom out the current suspension quicker off road or even crossing a bump in the road. Have you had any problems with that?37s, no lift, no level, no trim, no rub! Just installed Method NV305HD custom painted Agate Black with Toyo Open Country A/T in 37x12.5x18. Was planning to trim and level but zero rubbing so may not. Speedometer is off 3 mph at 65 (really running 68) based on Garmin GPS. 2021 F350 Lariat with 6.7
