My 2024 Tremor is also in the shop for this same thing. They said they cant hear it, but are going to use chassis ears on the axle today. I swear it has gotten louder over the last 500 miles so I have no clue why they cant hear it
The sound only changed with road speed. Engine speed or throttle input didn’t make the tone of the sound change.I’m hearing a whirling noise as of today it seems to get louder when I let off the gas… is that how yours was?
That's a great report and I'm sure adds confidence back into the truck and your dealership as well. It is unnerving to spend so much for something and then find it has what could be a major issue. As they say, everything is fixable, but getting it right so quickly is the best feeling. Thanks for sharing!Picked the truck up today and it is fixed. They ended up replacing all the bearings and seals in the rear axle. I see new shims as well, so it looks like they just completely re-setup the whole thing. They said it must have been some kind of contamination that had gotten in the pinion bearing. They never found any metal but could see scoring in the bearing.
It is quiet now and the gear setup seems great. No howling or whining. Only noise is the Duratrac tires.
Fixed the steering wheel pointing to left issue as well. Alignment was checked and was good. I thought he said they took the steering wheel off and put it back on straight. It doesn't sound like that in the writeup though. It says the electronic actuator not aligned with steering gear for wheel centered conditions. Whatever they did it seems perfect now as well. It was pretty far off to the left when I brought it home.
Good luck. I have almost 1k miles on mine since they fixed it and the rear end is still quiet. Can’t say the same for the 10 speed transmission. It is whining pretty noticeably from 3 through 6 now. It seems like everyone says this is normal though due to the straight cut gears on the hydraulic pump.Mine ('23, 17k miles) went into the shop yesterday for rear-end noise and vibration. Sounded like pinion bearing because it would change based on acelerator/driveline angle. We'll see what they find when they tear into it on Monday.
