Ok so I thought I would make a thread about all the towing issues as I come across them and put them all in the same thread.
So far the bad:
2.5inch receiver is measuring an 1/8th inch over sized (2.625" to 2.640" measured with my mitutoyo calipers), leaving .0625" play per side.
- I can't find a tolerance chart online but I'm assuming an 1/8th oversized is too much.
- My shank measures 2.450" which would be acceptable if the receiver opening was on size.
- So with the difference of the receiver opening and my shank size, thats almost an .100" total play side to side. That is not acceptable.
Steering wheel pulls left when towing, but only when towing. This could be a bad alignment with the trailer or something with the WD hitch so I'm not putting blame on Ford just yet)
-Pulled my trailer without the WD bars attached and there was no pulling which leads me to believe it is something with those. Possibly the bar hangers need to be adjusted. Its not anything wrong with the truck though.
Brake light warning came on all of a sudden on my second trip around the block. It was fine at first, I went through the trailer setup process and everything was fine. Now its telling the right brake light/blinker is out but the weird thing is that its working. I get the warning, go check and everything is fine. The lights on the trailer are not malfunctioning. I did not have this issue with my 2019 F150 I literally had hooked up about a week ago.
-Brake Light warning is gone. I cleaned out the terminals on both the truck and trailer and this fixed the issue.
Backup camera resolution is horrible... Its like 240p at best. The image looks like grainy dog poo on the 12 inch screen.
The "zoom in" button (+ symbol top left) doesn't always work. I have to press it MULTIPLE times for it to eventually work.
-I have found that switching to the bed cam and then back to the backup cam fixes this issue, although still annoying.
So far the Good:
Truck has zero problem pulling a 12k trailer with the 7.3L gas engine. It pulls so much better that my F150 did as far as acceleration and off the line get up and go. Very happy with that. Granted I only went around the block a few times and briefly on the freeway.
Noticeable less sway and WAY better braking. I actually had to turn down the gain on the brake controller. I had it maxed on my F150 before.
Tow mirrors are awesome, I didn't have the extendable mirrors on my F150.
I had no problem connecting my safety hooks to the receiver. I know some people have reported issues but I did not.
I like how it remembers to use tow haul mode with my trailer attached after I shut it off and turn it back on.
I will continue to update this thread as I encounter more issues or fixes for issues previously brought up.
So far the bad:
So far the Good:
